wheel sizes, gear ratios, and bucking trannies
Old Dec 15, 2004 | 12:58 PM
dorrington's Avatar
Ive got 18" wheels on my wrx...how does this affect all the gearing in the car? What I mean is, will my top speed in x gear be significantly different? What are the top speeds for each gear, stock?
Also, is the speedo affected? I feel like when I drive the speed limit, everyone is driving faster...but it seems like with the larger diameter the speedo would register and slower speed (since the wheel turns less for a given speed).
Also, just out of curiosity, what causes the bucking when you're in a low gear and your foot is off the clutch pedal, but not on the throttle? Like when youre in first cruising around the parking lot, and it bucks if you aren't using one of the two pedals. Is this just friction? But if it is, why the 'bucking'...why doesn't is just slow down?
Old Dec 15, 2004 | 02:18 PM
Wingless Wonder's Avatar
It's the overall diameter of the tire that determines compatability with the stock speed sensor. For an increase in wheel diameter, the aspect ratio of the tire must be decreased numerically to maintain a similar overall wheel/tire height and diameter.
https://www.i-club.com/forums/showth...eet#post411480
Old Dec 15, 2004 | 02:23 PM
Origami posted by dorrington
It's not friction. It's the lack of driveability in a small-displacement, low-compression engine at low engine speeds (RPM). Drive a Mustang GT or late model Corvette in first gear at the same speeds and you'll find they are very smooth - lots of low end torque.
Old Dec 15, 2004 | 07:45 PM
dorrington's Avatar
hmm..interesting...
but it occurs between 2 and 3 thousand rpm i feel, and thats about cruising rpm. basically you're saying that the engine doesn't "like" to be at that low end?
Old Dec 15, 2004 | 08:32 PM
dorrington's Avatar
oh yeah...i DO keep it smooth, but I was curious to know what it was that caused it to buck...I figured it was engine braking, but I didnt know why it jerks
its done it on every car I've owned if you dont use the clutch enough. usually if you keep your foot on the throttle just a bit, it stays smooth but you slow down...or you could just shift to 2nd...
lildragn11
Sep 26, 2004 03:33 PM
ac_attack
Sep 7, 2004 07:44 PM
six1five
Dec 15, 2003 10:07 PM
six1five
Dec 14, 2003 06:04 PM
gpatmac
Aug 12, 2003 02:53 PM
