19" Wheel fitment Help Wheels Experts
Old Mar 12, 2003 | 10:38 AM
Luke@tirerack's Avatar
iClub Platinum Vendor
Car Info: 2001 Porsche 911
they will rub ..... the offset needs to be a minimum of 48mm
Old Mar 12, 2003 | 12:06 PM
the OE wheel:
when measured from the mounting surface:
outward edge of wheel 27.55mm
center line of the wheel sits 55mm inward
inboard lip sits in 137.55mm
19x8 ET35
using the same measurements
66.6mm
35mm
136.6mm
so the outer edge of the wheel is over 1.5" from where the wheel is now and the center line is almost an inch outward of where ist is supposed to be. these conditions will cause tire rubbing and changes in the scrub radius, ackerman angle and other steering geometry angles, that to me is unacceptable, and will hurt the handling. Not to mention the additional torsional forces on bearings and suspension components. ... these are the facts and I do not care what the Konig fitment guide tells you the wheel they list WILL NOT FIT CORRECTLY !!!!
Old Mar 12, 2003 | 12:41 PM
cool ... glad to help ... but, I deleted your e-mail since I answered it here
Old Mar 12, 2003 | 01:15 PM
Rapid_Roo's Avatar
Car Info: 03 WRX | 95 GC
Originally posted by Luke@tirerack
the OE wheel:
19x8 ET35
66.6mm
35mm
136.6mm
on a different not, what type of dimensions should I be looking for in a wheel, if I wanted to get the widest tire possible on there in an 18" wheel. I currently have an 03 WRX with the full SPT kit, but I think I will switch the springs for H&R's to get a bit of a drop.
thanks in advance.
itzpoorboy
Jun 15, 2012 10:03 PM
ipozestu
Nov 25, 2009 10:48 AM
DetailAddict
Mar 19, 2009 10:44 AM
jyhighsky
Jan 25, 2006 10:02 PM
