APS Parts are Here !!!
We have been trying to keep this deal quiet for about 6 weeks and today it finally arrived. A huge truck with over $150K worth of APS parts. We are doing 3-4 huge buys every year and are one of the largest stocking dealers of APS parts in the nation. And just for this week we will be doing free shipping on ALL APS PARTS ! Here is the list of Subaru parts we have currently.
APS Part # and Quantity in stock
Tube headers equal length, polished stainless steel to suit US Spec STI (up pipe required) APS SSTI-EMK/02 = 5
Stock position turbine inlet (up pipe) 321 Stainless Steel cat delete with 321 SS flex section - to suit APS headers APS SSTI-TIP/07 = 5
Billet Fuel Rails All pre-assembled teflon/ss lines, steel fittings. -Side feed injectors APS STI-FRP/01 = 5
Heat Shields to suit APS Headers APS STI-HKS/01 = 5
Conversion Kit- Permits simple installation of any APS FMIC to 06/07 models APS WRX-FMI/CK = 5
DR725 Front Mount Intercooler Massive bar and plate core 4.5" Thick. Rated to 725+ HP Specify BLACK************ finish APS WRX-FMI/R4 = 10
DR725 Front Mount Intercooler Massive bar and plate core 4.5" Thick. Rated to 725+ HP Specify SILVER************ finish APS WRX-FMI/R4 = 2
DR525 Front Mount Intercooler. Serious bar and plate core. 3.25" thick. Rated to 525HP Specify BLACK************* finish APS WRX-FMI/R6 = 25
DR525 Front Mount Intercooler. Serious bar and plate core. 3.25" thick. Rated to 525HP Specify SILVER************* finish APS WRX-FMI/R6 = 2
APS 65MM Cold Air Intake for Subaru APS WRX-HFA/01 = 10
Compressor Inlet Duct -3" ID hose/tube construction APS WRX-CID/01 = 10
Dual Vent Blow Off Valve, Direct bolt on to any top mount intercooler APS 995-047-000 = 10
APS 70MM Cold Air Intake for Subaru APS WRX-HFA/02 = 10
Turbo back exhaust system, 3" polished 304 stainless steel tube, flanges, TIG welded - single 4" tip - 95 DB APS WRX-HOE/R1 = 10
Dual vent blow off valve direct bolt on. Protect turbocharger at high boost levels. Improves engine response on gear change APS 590-047-000 = 5
Turbo back exhaust system, 3.5" polished 304 stainless steel tube, flanges, TIG welded - single 4" tip - 100 DB APS WRX-HOE/R5 = 5
Top Mount Intercooler. Bolt on bar and plate replacement for stock unit. Rated to 375hp Suites all driven and thottle by wire vechicles. APS WRX-TMI/06 = 5
TSR70 Turbo System- split scroll turbocharger, split scroll up-pipe, tial wastegate 3.5" turbine outlet pipe to any APS exhaust, all hoses/fittings included. 700hp (flywheel) APS WRX-RMT/03 = 5
Tumbler Valve Delete provides provision for auxillary injector mouting. Top feed injector -No tuning re. APS WRX-TDI/01 = 10
Billet 5/8" ID Rails regulator mouting block. All pre-assembled teflon/ss lines, steel fittings. -top feed injectors APS WRX-FRP/03 = 5
3" flanged act converter, high flow, high temperature - suits all 3" APS systems APS 995-019-200 = 2
High FLow Cold Air Intake, Rotated Mount Turbocharger NC Machined. 65/80mm ID APS WRX-HFA/R9 = 5
PM or email me if you need more details or have any questions. Thank you.
Car Info: 98 2.5RS WR Blue (breathin fire/not on fire)
any GC8 fmic kits? i know APS makes one that works great with conversion cars.
I believe this is the part # (APS APSWRX-FMI/9)
hey i was wondering if u could give me a price on that up pipe and on the headers? i do want to know if u have a ny unequal length headers aswell? and are the headers ceramic coated?
wrx-sleeper
Apr 11, 2007 12:18 PM
ewright
SoCal Classifieds
17
Oct 12, 2005 06:23 PM
ewright
20
Oct 8, 2005 11:32 AM
995047000, air, aps, apswrxfmick, apswrxfmir4, conversion, dr525, duct, fires, front, gc8, inlet, intercooler, mount, suit
