Used Aftermarket Car Parts For Sale Only second hand aftermarket car parts can be listed here by private parties only!
Nitrous kit,wrx stock&aftermarket stuff
Old Aug 20, 2004 | 03:26 PM
AK'S REX's Avatar
Still got some stuff to get rid of. Everything off 02' WRX w/ about 35k miles unless otherwise mentioned. Make offers on the following, I would prefer paypal.
Factory 02' WRX parts:
-downpipe, axle back, w. hangers
-intake resonator, rubber accordian tube between maf and turbo inlet pipe
-turbo inlet pipe w/ top plastic vacuum fitting snapped off
-springs
-fuel pump
-air splitter
-coolant overflow tank
-spare tire
-many factory rubber hoses and lines, etc.
Other parts:
-K&N panel filter for stock box used for less than 10k miles
-4 brand new STI spark plugs in box, same as seen here http://www.kastleskorner.com/store/...products_id=401
-52mm Greddy EGT gauge only, no wiring & thermocoupler(white face)
-Nitrous Works single fogger wet NOS system. all brand new in packaging. Also have nitrous safety system which has a fuel and oil pressure sensor that will de-activate the system if anything drops below normal levels. Also has a nitrous safety valve that will vent the nitrous if the solenoid should stick open, or if something should go wrong. Also have brand new edelbrock purge kit with everything necessary for install. Another cool thing about this system is that it vents the ntirous between the solenoid and the fogger nozzle every time the throttle is released(i.e. shifting gears), it vents it through another line just like the purge.
Everything included for install in any subaru or almost any fuel injected car. Looking to sell as a package. 10lb bottle is full. Paid over $900 for everything.
On EBAY now http://cgi.ebay.com/ebaymotors/ws/e...&category=33740
-02' USDM EJ20 shortblock w/ 12k miles after rebuild. Motor spun a rod bearing, and I pulled it immediately thereafter. Built with JE stock bore pistons and rings, Eagle H-beam rods, and a cleaned up crank. Make offers, like to sell shortblock as a whole if possible. Or may entertain offers on seperate parts.
Many or most pics here, more to be added soon. http://www.imagestation.com/album/?id=4286403719&idx=29
More parts most likely to be added soon. Let me know if you have any questions.
-AK
Imprezd
Feb 22, 2003 02:49 PM
NotoriousWRX
Feb 4, 2003 05:32 PM
Imprezd
Jan 30, 2003 01:46 PM
East Coast WRX
Jan 30, 2003 07:36 AM
