95 Impreza Rally car PARTOUT Open class
Hey all. New to the forum. I have my rally car to part out.… Need some help paying the mortgage in between jobs.. Camera broke, So I’m borrowing a friends. I’ll have pics up this weekend.
Shell 95 Impreza L 2 door AWD coupe. Clean title. Never wrecked. No body damage. Complete Rally-America / NASA Approved welded cage. Very tight bends, Beautiful welds. The cage attaches to the body at 16 points. Front and rear strut tower cage mounting. $2,500.00
1991 Ford F-350 7.3L Diesel dually 14 foot box service truck. 250k. NEW EVERYTHING! New Tires, Brakes Fuel pump, water pump, belts hoses, Air filter, 2 new batteries, Oil just changed Coolant, Power steering fluid. Clean title never wrecked, Custom hitch, 3spd auto great on the milage. 3000.00
ALL PARTS ARE IN GREAT WORKING ORDER UNLESS SPESCIFIED! I will try to make aware of any damage to avoid any mishaps.
I accept PAYPAL ONLY! I will ship Everything USPS. Heavy items will be shipped UPS or freight. Shipping IS NOT included in the price. Please PM me with ZIP code and what you want. I’ll give you a total.
OEM Parts for sale.
Turbo cross member $100.00
EJ20 Starter. Fits all $20.00
1 2001 2.5RS Rear Diff $50.00
1 2001 2.5RS Rear Diff. 50.00
1 Rear drive shaft Half shaft 29.5” ( with mount bearing) $25.00
1 22 spline Drive Shaft 60” $50.00
1 Front Drive Shaft 93-03 Impreza Legacy Wrx $20.00
1 Rear Drive Shaft 93-03 Impreza Legacy Wrx $20.00
1 Rear Drive Shaft 93-03 Impreza Legacy Wrx$20.00
1 Front Drive Shaft with Tone ring. 93-03 Impreza Legacy Wrx $30.00
1 Front Drive Shaft BOOT REMOVED. I removed it for another in a rush.. It just needs a new boot. $15.00
1 Front Drive Shaft Broken boot. $10.00
Intercooler Y-PIPE $10.00
1 Trailing arm GC body WRX $20.00
1 Trailing arm GC body WRX With Body Mount $30.00
1 Trailing arm GC body WRX 20.00
1 Lateral Link $10.00
1 set of 4 OEM 5 star 15” Aluminum wheels. Fits ALL Subies 93-04 $100.00
1 set of 4 OEM Steelie wheels Black fits all 93-04 $50.00
1 set of WRX Upgrade front brake setup. Includes Porterfield R4 pads, Magnum Cross drilled Rotors and WRX calipers (ground to fit 15” wheel.) This is a direct swap for any Impreza, or WRX. Upgrade for both.
Rotors are true Never turned. 90% material remaining. Awesome upgrade for those crappy stock brakes (Cost-effective) 150.00
1 set of rear 2.5 RS WRX Calipers, Brembo Dimple drilled rotors, and AXXIS pads 90% material remaining Rotors are true. Never turned 100.00
1 pair WRX STI Impreza Goodyear Stainless Steel brake lines. Front (1 side has small broken plastic NOT a big deal) 35.00
1 pair WRX STI Impreza Goodyear Stainless Steel brake lines. Rear 40.00
1 set NEW Subaru 2.5 WRX Brembo rear Brake rotors Dimple drilled C728L C728R
1 set of NEW BPI-2001-EE-1165 Performance brake pads by Axxis
Gauges $100.00
All Gauges are in Good working order. They all come with mounts and bulbs. NO BOXES OR DIRECTIONS INCLUDED!! All of these are VERY easy to install!
1 EGT Pyrometer gauge New Auto meter. 90.00
1 EGT Pyrometer gauge Auto meter. 80.00
1 Oil pressure gauge with sending unit Auto meter. 40.00
1 fuel pressure gauge with sending unit Auto meter. 50.00
1 Air/ fuel Raito Gauge Digital Auto meter. 40.00
1 Boost pressure Gauge VDO 50.00
1 Voltmeter Auto meter. 25.00
1 Spitfire 3” tachometer $15
1 Water temperature gauge Auto meter. 40.00
Seats
1 Corbeau FX1 Wide racing seat Black. Back has some scratches on it. Has a couple small tears in the top and left side. missing a couple belt trim plastics.. $125.00
1 Corbeau Ultra II Racing seat Blue FIA Homogulated Missing the 2 top 5 point plastic trim. $170.00
Rally parts
DMS 50MM coilovers. I had them rebuilt once. I rallied 2 times on them. They are straight no leaks FRONT AND REAR Set of 4 $800.00 They do come with top hats (Subaru OEM) They will fit ALL Subies 93-01 And WRX
1 set full mud flaps With Aluminum brackets and bolts 100.00 Custom made from sheets of Flap material.
Mud flap material (couple extras and material to make 4 total) 50.00
8 pieces Roll cage padding FIA Homogulated Required by RA $100.00
Terraphone Professional Intercom system 100.00
2 Terraphone practice headsets 1 missing foam boom piece. 25.00 ea.
2 Helmet Hooks 1.5 inch tubing. . Black 5.00 ea.
Co-Drivers Map light 18” 12v $25.00
Co- Drivers foot rest. Aluminum. Very nice! $50.00
Terratrip 303+ Works but has a problem. $100.00
Terratrip 202 and 303 foot pedal NEW 25.00
Comp Brake Rear brake controller with handle . Comes with proportioning valve. 150.00
Kill switch with over 6 feet of 0/1 cable. Complete with key. $50.00
Stinger 80 amp Light pod wiring harness. Includes wiring, stinger 80 amp pop breaker, stinger 150 amp power distribution block, pod connector and toggle. This will wire into most any vehicle. $75.00
Sparco Racing steering wheel with hub adapter. Will fit Subaru, Mitsubishi Toyota, and Honda. I’m sure others too. $150.00
Misc Under Body plastics. HTPE Driver/ co-driver sides rear suspension canvas and fuel tank protection. 100.00
Rear diff Skid plate $50.00
Primitive skid plate 3/16” Aluminum. Custom mounting required. Had some damage that was pounded out. Still functions perfectly. 100.00
Version 6 STI Wing with LED brake light. Painted red. Clean paint no chips/ cracks. Has some orange peel. Needs to be cut and rubbed. Nice! Used PPG Paint and primer $200.00
STI Hood Scoop Cracked in 2 center braces. I repaired with ABS plastic weld with great success! No noticeable damage. Painted red. No chips or cracks in paint needs cut and rubbed (minor orange peel) PPG $25.00
Engine
EJ20 V2 motor. No turbo attached. This motor runs great. I ran a VF-39. It produced 289HP The heads were ported and polished Converted from multi-coil to single using MSD components. Always ran Royal purple.
Will include PS pump and Alternator I do have a pallet and will ship this through a freight company. I do prefer local pickup on this. $1000.00
Link Engine Management System. Full wire in Engine management 500.00
Link EMS harness With all sensors and pigtails I’d like to sell it with the Link or the motor .. Or all as a package..
ACT 9.5 pound Aluminum Flywheel 93-01 Impreza $100.00
Cobb Pulley 75.00
Engine Grounding kit. 15.00
WRX Radiator Visteon. Not OEM 100.00
No name 3” Cold air intake tube and filter $20.00
Turbo XS RFL Blow off valve. $75.00
Sparco hood pins $10.00
ACT 6 puck push racing clutch kit. Comes with Stage2 Pressure plate 6 puck solid hub friction disc and alignment tool. 90% material remaining. 150.00
3 inch Mandrel bent Exhaust Turbo-Back set-up Includes:
HKS Down pipe with flex pipe, 3 inch mandrel bends, High flow catalytic converter Magnaflow Muffler, 2 Oxygen sensor bungs and 1 EGT bung tight @ mouth of down pipe. All mounts will fit RS WRX STI. Idk about Legacy.
This is 1 solid piece. I can cut and mark it if need be for shipping. Any muffler shop could weld it back together and put it on for you for less then 50 bucks. I do prefer local pickup though. This Exhaust was custom made. It cost me over $900.00.. The sound is Great! The performance is very noticeable! $500.00
Custom made Sheet metal dash board. Has total of 8 holes for gauges. Fits snug to the trim lines. Not bad for what it is. Has extension for co-drivers toggles painted flat black. Lighter and easier to remove than stocker. (6 bolts)
Fits GC body $100.00
Rally Tires ***
20+ Yokohama A035 205/65/15” tread 80%-90% remaining 30.00ea.
2 Michelin M5 Compound 14/60/15” 20.00ea
4 Michelin M4 Compound 14/60/15” 40.00ea
4 Michelin M4 Compound 14/60/15” 20.00 ea.
Gator Products Spill Kit. Never opened. Dirty from rally.. 15.00. Half the price! Order the stickers from for free . Ifyou ever use the spill kit, They send you another for free. (as long as the stickers are on the car and you take a pic.)
More pics and Items to come By the end of the weekend.
OEM Parts for sale.
Gauges $100.00
Seats
Rally parts
Engine
Cobb Pulley 75.00
Rally Tires ***
15" wheels. with the ground calipers I have yes.
Last edited by Thezilla; Feb 23, 2009 at 08:41 PM. Reason: because I spelled brake wrong...
dam... ight nevermind...
im trying to get some 15's so i can actually get rally tires for myself for rallyx...
thanks anyways.
i plan on being in rally america in 2 years btw
thanks anyways.
btw, try posting this on Dirtyimpreza.com
you'll have everything gone in an instant, its an offroad subaru site. hit it up
ryan~
ryan~
