Coilover adjustments
Old Jan 25, 2016 | 09:14 PM
WRX-Ray's Avatar
Hey everyone,
Here is my dilemma, I've researched different forums and have not found the answer I am looking for. I just switched to ISC coilovers from OEM struts with Tien S-tech springs. After preloading the coilovers, I adjusted the ride height. I used a tape measure and measured the distance between the edge of my rim to the wheel well fender. I got the same measurement all the way around and it is on point. When I measure the distance from the ground to the top of the wheel well fender i get a different measurement on different sides of the car. It's by 1/8th to 1/4", but when i measure from the wheel to fender, it's even all around, but not when I measure from the ground up. Is the normal or should i get my measurement from somewhere else.
Thanks in advance.
Old Jan 25, 2016 | 09:17 PM
Rev. Rob Large's Avatar
Call me Pebbles
Car Info: Moist
Check air pressure in the tires.
Old Jan 27, 2016 | 10:22 AM
bmxhotsauce's Avatar
Car Info: subaru
you should never measure from ground to fender. its a HUGE NO NO !!!! always measure hub to fender. you do not have an issue at all.
scarface
Jun 22, 2006 10:00 AM
vinman
Nov 30, 2005 07:22 PM
myroncuz
Jun 24, 2005 08:59 PM
djQspin
Mar 10, 2005 11:04 AM
AWDrifter21
Aug 1, 2004 07:54 PM
