rs sway bar question (larger diameter than L model?)
Old Jan 22, 2008 | 03:36 AM
97impreza's Avatar
Car Info: 1997 subaru impreza
are the rs sway bars and larger than the sway bar from an "L" if so how much larger?
thanks for any help.
Old Jan 22, 2008 | 10:28 AM
darkonion's Avatar
Chicks dig me. April Fool's!
I am not sure. I think they are the same. I think it is the 13mm toothpick in the rear.
Old Jan 22, 2008 | 04:50 PM
97impreza's Avatar
o alrigth thanks
Old Mar 27, 2008 | 02:52 AM
Latka's Avatar
Car Info: None.
The Rear bar we pulled off my '98 L looked like a #2 pencil that was painted black. I had a 17 and a 20mm swaybar that I picked up (WRX / STi?) - maybe the RS had a 15 or a 17 or somethin' around there.
Old Mar 27, 2008 | 12:15 PM
Racecomp Engineering's Avatar
Former Sponsor
Car Info: every subaru ever
picking up a 20mm rear swaybar from an 02-03 wrx is a great cheap mod that is very noticeable.
- Andrew
Old Mar 29, 2008 | 09:00 AM
not12listen's Avatar
Car Info: 06 WRX Wagon
i took the stock 13mm rear sway bar of my 99RS and put an 02/03 WRX rear sway bar on (which is 19mm) and it did make a noticeable difference. there is less motion from the rear, and the steering seemed to tighten up just slightly.
was it worth it? yes.
is it so noticeable that you'll suddenly think that you're a WRC champ? no.
Sea Dragon Rex
Nov 15, 2010 01:48 PM
pwn
Nov 5, 2006 12:18 PM
UgLiEz
Wanted
Dec 1, 2005 10:56 PM
Rat
Jun 5, 2005 11:04 PM
GottaREX
Feb 25, 2004 09:37 AM
