Rear brembo conversion kit for WRX
Old Jul 22, 2005 | 09:22 AM
subywrx's Avatar
Rear OEM brake conversion kit
What OEM rear brake kit will be a big upgrade?
Old Aug 2, 2005 | 10:20 PM
STi rears
or the other two pots i forget what they come on
Old Aug 15, 2005 | 07:41 PM
PyroManiac's Avatar
From: Are you too one of the few still living the past? Well I can change that! With a simple wicket. Yes, my friend, a wicket. PM for details.
Car Info: No car right now....sob.
Subaru makes some JDM 2 pot ones, but you'll need to swap over the whole brake hub.
Old Aug 26, 2005 | 05:04 PM
wrxtasy555's Avatar
Car Info: 2002 Wrb WRX sedan
You can add the JDM 2 Pots or Brembo rears rather easily. Most places sell kits with brackets in order to make them fit without replacing the hubs. One thing to look out for is to get rear rotors with spacers inside so that your e-brake is still functional.
Old Jul 13, 2006 | 01:02 AM
blue05wrx's Avatar
Car Info: blue05wrx sold, evo IX MR
Is it expensive to replace the hubs. I have a 05wrx and planning to get both the front and rear sti brembos. Where can I get the conversion kit for the rear and how much do they usually cost?
Old Jul 13, 2006 | 10:01 AM
TheScoobyMedic's Avatar
Car Info: 05 wrx
you dont have to switch out the entire brake hub for the 2pot subaru calipers, you just need a new backing plate for the new rotor size and has new points for the caliper to mount on, these are sold in almost all 2pot rear kits
Old Jul 13, 2006 | 10:03 AM
Car Info: 05 wrx
the sti rears wont fit our wrx's, unless you wanna go to a 6speed transmission with a R180 rear diff, get some STi axles and swap out the entire rear end (and yes thats upwards of $8,000 without labor plus the money to buy the front and rear STi brembo's)... brembo makes big brake kits for the wrx and the kit comes with the gold brembo calipers just like the STi's, gruppe-s sells em
JMeltzer4
Jan 3, 2013 05:15 PM
speedykanaan
May 24, 2012 08:41 PM
MonsterGC
Oct 14, 2010 01:12 PM
osofast
Feb 19, 2006 12:55 PM
nathanellis
Dec 23, 2004 11:41 PM
