Rear brake screaming & HOT
Old Aug 11, 2004 | 07:33 AM
Gleb83's Avatar
Car Info: 2002 Alpine White WRX
Just a thought but maybe the handbrake needs adjustment. You can tell it's draging against the rotor if the rotor are very hard to remove and install. If that's the problem I bellieve you can adjust them but turning a **** that's on the bottomb of the brake assembly and can be seen once the rotors are removed.
Old Aug 11, 2004 | 08:34 AM
jdepould's Avatar
Car Info: 1990 thing
sounds like the e-brake is sticking, I had that and I had to replace rotors and calipers
Old Aug 11, 2004 | 10:50 AM
jdepould's Avatar
why don't you think so?
Old Aug 11, 2004 | 12:37 PM
jdepould's Avatar
If you push on the brake, you aren't trying to accelerate, therefore it's not going to be making crazy noises. I'm not sure where it's adjusted, but I had to have a bunch of stuff done to fix it.
Old Aug 11, 2004 | 01:50 PM
It's not the e-brake, that doesn't clamp the calipers. It couldn't heat up your whole rotor that bad. The cheap pads you got are probably just a bit too thick.
Old Aug 11, 2004 | 02:07 PM
jdepould's Avatar
I dunno, he wasn't very specific about the heating.
excel
May 27, 2006 05:16 AM
WRXspeedster
13
Jul 26, 2004 02:15 PM
HellaDumb
Oct 1, 2003 04:01 PM
