Problem BC Racing Coilover
Old Oct 29, 2007 | 01:37 PM
Gilbert927's Avatar
Car Info: 05 WRB WRX
the problem that i had was that i adjust the spring (i didnt had the instructions). Found the instructions online and does anyone know the spec or preload of the spring. right now im just keep playin with them and i believe i got the front almost right but the rear is another story.
question on the spring, with one hand cant not move them and two hand u can move them.
Have anyone bought the coilover yet and havent install it, i need the measurement. BR model.
Old Oct 29, 2007 | 04:01 PM
ill try to find some one
Old Oct 29, 2007 | 04:36 PM
WillisW555's Avatar
Car Info: '09 MX-5, '09 IS-F
Ask ImportImage. He'll know or else he can get you in touch with the guys from BC.
Old Oct 29, 2007 | 07:42 PM
Gilbert927's Avatar
also wondering how the car feel when havent adj to right setting for the damping on ur car.
Old Oct 30, 2007 | 10:18 AM
charlesj's Avatar
Staff Member
Car Info: 06 STI
You do not want to preload the spring, just get it snug so it does not move. So you simply start with the upper ring loose and then move up until the spring does not move up or down and then about another half to full turn to snug it up. If you have it up so far that you cannot easily turn it with one hand, it is too tight.
Old Oct 30, 2007 | 02:53 PM
Gilbert927's Avatar
i believe explain the way to adj the height. i havent adj the height yet. right now i want to get back spring the way back from original spec.
i want to know the feel of the spring or can u turn it with one hand or two or something.
Old Oct 31, 2007 | 08:15 AM
Gilbert927's Avatar
Bump
Anyone
Old Nov 1, 2007 | 11:31 AM
WillisW555's Avatar
This is my best advice. Based on the thread on Nabisco, they are very helpful.
Old Nov 6, 2007 | 01:11 PM
charlesj's Avatar
Staff Member
Car Info: 06 STI
As I said, you should be able to turn both the ring and the spring itself with one hand pretty easily. If you cant turn the spring or the ring by hand, then it is too tight
Old Nov 6, 2007 | 06:52 PM
Gilbert927's Avatar
right now i goin with the spring feeling by hand. ur opinion one hand push it lighty u cant turn it and pushing it hard u can turn it. or two hand pushing it lighty cant turn it and push it harder can turn it.
Old Nov 7, 2007 | 07:10 AM
charlesj's Avatar
Staff Member
Car Info: 06 STI
Right. It should have a little resistance making it so it does not spin freely with one hand, but can still be turned quite easily. The easiest way to get this right is to loosen it until the spring is flopping around. Then tighten it until it has no room to move up or down. Then add one or two turns to snug the spring in place.
Old Nov 7, 2007 | 08:43 PM
Gilbert927's Avatar
thanks, i will try it this week. so u r sayin that turn it by one hand easily or hard by pushing it or turnin the spring.
Old Nov 8, 2007 | 02:24 PM
austinp02's Avatar
Car Info: 03 wrx vf34 281hp/276tq
give bc racing a call. or go here and read through it.
http://forums.nasioc.com/forums/show....php?t=1085379
lots of good info there and you should find contact info for BC who will help you. there are also some good diagrams and stuff. gl!
Old Nov 12, 2007 | 01:10 PM
Gilbert927's Avatar
i did the adjustment and better then before. it still bounce but worry about when i drove it over bump like big ones, it doesnt sound right from the rear.
Old Nov 13, 2007 | 11:51 AM
charlesj's Avatar
Staff Member
Car Info: 06 STI
You may want to tighten up the dampening if its too bouncy
