Need parts list for rear disc convert: 96 impreza brighton
Want to swap my rear drums for discs on my 96 impreza brighton 1.8 awd 2dr (GM2?). Already have wrx wheels to clear, so was wondering what car i might scavenge parts from (RS, WRX, legacy 2.5GT...) or if they are all different. Will I need to swap master cylinders, proportioning valves ( and if so where are they located?), ebrake parts, lines, fronts too for correct modulation?.....or is this a dumb idea and should I save my pennies for a four wheel conversion from aftermarket or STI. Ive already installed the suspension from a 2000 2.5RS (Struts, springs, anti-roll bars, arms with mounts for the bars in the rear). Help me create my underpowered monster, a super 1600- wanna be.
thanks,
Dylan Cole
thanks,
Dylan Cole
old post but i thought id throw my input.... in.
MC/proportioning valve is fine, you can leave them as is. all cars up till 96 had the same valve, just used different boosters.
what you should look for is a '96 legacy rear discs ... now the fun part. you have to swap the rear hubs to upgrade to discs. basically what your going to need is the hub, the caliper, rotor, back plate, and your going to either have to grab the legacy e-brake cables or get some off an impeza w/ rear discs.
ohh... and pads
ohh... and pads
jakeg
Mar 26, 2010 10:38 AM
96Imprez
Jun 25, 2008 06:02 PM
