Need help w/ STI adj struts
Old Nov 12, 2007 | 07:30 PM
Mwizard's Avatar
Car Info: 2002 WRX Stage 2 upgrade and Formula Ford
I have STI pink rebound adjable struts. The adjuster is a sloted plastic "screw"( inside a nut) w/ a white dot and 4 numbers on the nut. So, the problem is ... since I autocross my daily driver, I change the setting frequently and I have messed up the slotted screw to the point I can no longer tell what the setting is on the front struts. I need to replace the nut and screw adjuster. Can anyone point me to a source for this part? And what does it take to change it?
Mark
Old Nov 21, 2007 | 11:03 AM
darkonion's Avatar
Chicks dig me. April Fool's!
Hey Mark,
I dunno. But I'll give you a free bump.
darkonion <--- Kevin <--- 1997 Impreza L with CF hood
One of the pics you took.
Old Nov 29, 2007 | 07:05 AM
charlesj's Avatar
Staff Member
Car Info: 06 STI
Any chance you could post a picture?
Old Nov 29, 2007 | 07:33 AM
VRT MBasile's Avatar
Thats such a uncommon part I think your best bet is going to be asking local vendors if they can order the part or (gasp) going to the stealership for a $40 bolt and plastic screw
Old Nov 29, 2007 | 10:04 AM
Mwizard's Avatar
Talking A picture
Here is a link to my Zenfolio site.
http://markm.zenfolio.com/img/v2/p341122757.jpg
I just figured out how to add a picture.
Hope this helps. You are looking at the bottom of the strut. This is a rear one which is not so warn out.
Thanks.
Mark
Attached Thumbnails Need help w/ STI adj struts-_j5v8221-version-2.jpg
Old Feb 1, 2008 | 01:44 PM
Mwizard's Avatar
Problem solved
Someone pointed me to the manufacturer of the struts(for Subaru),kyb, and after 3 tries(in the mail), I got the replacement parts(for no cost).
Thank you all for the help
Mark
Old Feb 1, 2008 | 10:44 PM
darkonion's Avatar
Cool. See you bright and early on Sunday.
kaiba
Jan 22, 2015 01:40 PM
Lowball
Feb 15, 2005 10:38 AM
Lowball
Feb 11, 2005 09:45 PM
Mwizard
Oct 13, 2003 08:02 PM
