Need help picking out springs.
Old Jul 4, 2004 | 11:56 AM
wrx10404's Avatar
Car Info: 04' wrx
I just installed my Tein H-tech springs and i love em.
Old Jul 4, 2004 | 11:59 AM
funkdrmr's Avatar
Car Info: 2002 WRX Sedan - Silver
I've got the Tein S-Techs and love 'em. Here's a pic to show you the drop.
Old Jul 5, 2004 | 11:19 PM
Krinkov's Avatar
the Tein S drop lower and stiffer than the Tein H. Also the new 04+ Tein S drop even LOWER and STIFFER than the old Tein S for 02-03. If your looking for 1-1.75 drop the Hs are fine, also better matched if yo plan to use them on your stock struts.
Old Jul 6, 2004 | 01:08 AM
wasabi's Avatar
for all the guys with tein springs, what kind of struts are you matching with them? how's the ride?
Old Jul 6, 2004 | 09:33 AM
Krinkov's Avatar
is yours a wagon??
Old Jul 6, 2004 | 09:58 AM
platypus's Avatar
Car Info: dangerous with a wrench
general advice, if you're buying springs from japan, you will generally want to swap the front and rears. IOW, run the "front" springs in back.
The jdm cars these springs are designed for are significantly lighter in the front than the usdm cars we get, therefore there's a lot less understeer on the jdm car. With less understeer, they run stiffer rates in the front. Sine we get a lot more understeer, we actually want to stiffen the rear of the car to neutral-out the handling.
not that this actually addresses your question, though...
Old Jul 6, 2004 | 10:19 AM
Krinkov's Avatar
Ive heard that on coil-overs, that use standardized linear rate springs, but on conventional springs on our struts the fronts and rears dont swap.
Old Jul 6, 2004 | 10:38 AM
eastbaysubaru's Avatar
Interesting info Platypus. It makes sense though as I'm sure our crash test standards dictate more metal (weight) in the front of the car. Are the WRX springs really swappable front to rear though?
-Brian
Old Jul 6, 2004 | 10:44 AM
Krinkov's Avatar
-Brian
I cannot stress this enough.
They will not swap.
Old Jul 6, 2004 | 02:27 PM
wrx10404's Avatar
Car Info: 04' wrx
I have the H-tech springs and they are fine on stock struts. BTW stock usdm struts are made by KYB. After those wear out i will probably go with the KYB AGX if i don't just get coilovers. Also whomever said that you can swap front to rear: try it . It will not work. I cannot speak for the S-techs but the ride on the H-techs are great. Not bouncy at all. Feels like stock only stiffer! Good luck
Old Jul 6, 2004 | 08:21 PM
Krinkov's Avatar
Originally Posted by fliggil
I spoke to Subaru, and apparently the issue is that the 04 and 05 have different struts. Looks like I will move onto something else until the companies start making springs for the 05. HIDs could be in my near future.
struts may be different but are you certain the springs wont fit on them anymore? it seems highly unlikely
