Need help.Anyone with progress swaybar and kartboy links
Old Mar 21, 2004 | 09:28 AM
Needles's Avatar
Car Info: 2002 WRB WRX
Put on my swaybar and links and they don't seem to fit right. Put the links on the inside of the bar, like the picture from the swaybar instructions shows.(There is no way they can go on the outside.)Now the endlinks lean in on both sides. There not straight. Aren't they supposed to be straight? A picture of someone's setup would help a lot.
Old Mar 22, 2004 | 07:57 PM
Needles's Avatar
They lean toward the inside of the car. They lean a little is this normal?
Old Mar 23, 2004 | 05:20 AM
04blkWRX's Avatar
Car Info: Black WRX, stock
Here's my setup, it's a whiteline bar with kartboy links. The links are on the outside, straight up and down.
Attached Thumbnails Need help.Anyone with progress swaybar and kartboy links-new-1.jpg
Old Mar 23, 2004 | 05:21 AM
04blkWRX's Avatar
For reference, here's the stock bar, stock links. Links on the outside again.
Attached Thumbnails Need help.Anyone with progress swaybar and kartboy links-old-1.jpg
Old Mar 23, 2004 | 09:40 AM
04blkWRX's Avatar
Originally posted by Rallysportz
^^Jeez, slap enought grease on those bushings??
Ha ha, yeah. I figured I had no further use for the grease packet so I might as well use it up!
Old Mar 23, 2004 | 01:28 PM
dewdrops12's Avatar
I have a progress bar and kartboy endlinks, at 1st look they appear to be under stress, in a similar way described, but if I look in relation to the ground, they appear straight up and down...
don't know if that helps...
Old Mar 24, 2004 | 06:41 AM
Needles's Avatar
dewdrops12
Did you put the links on the inside of the bar?
Old Mar 24, 2004 | 09:36 AM
dewdrops12's Avatar
No, the bar connects to the outside of the bar, it doesn't look like it would fit on the inside... the pics on this tread show the bar on the inside... I have had mine for about 10,000 miles, the links look like they lean in a little, but it seems to work well.
Let me know what you come up with...
also, they look the same with stock endlinks (I just put the kartboys on)
Old Mar 24, 2004 | 09:47 AM
Needles's Avatar
dewdrops12 Do you mean the endlinks on the outside of the bar.
Do you have a pic of your setup.My endlinks are on the inside of the swaybar.There is no way I can bend them to place them on the outside.It just won't work.Maybe they sent me the wrong swaybar.
Old Mar 24, 2004 | 10:14 AM
dewdrops12's Avatar
Sorry, I don't have a camera...
- Mine came with instructions, did you get instructions with your progress sway bar? If not, when I get home I can check to see what that says.
this may help? http://www.scoobymods.com/forums/showthread/t-23.html
If you look at these pics it shows the sway bar on the inside as well, but mine looks like they wouldn't fit on the inside...
look at the last pic at the bottom of that page, you see how the top of the endlink is leaning in -- that's how mine looks with the sway bar on the outside of the link, make sence?
Old Mar 24, 2004 | 10:18 AM
dewdrops12's Avatar
look at this as well
http://forums.nasioc.com/forums/show...gress+sway+bar
Old Mar 24, 2004 | 10:20 AM
Needles's Avatar
dewdrops12
Yes I got the instructions.It does not say with side to put the endlinks,but the picture shows the links on the inside of the bar.Thats how I installed them.
My links look the same way.SO I guess its OK.But my links are on the inside.
I will call Progress today and clear this up.
