Making a GC8 top fit on a GDA
Old Apr 8, 2004 | 06:39 PM
AlBlueCar's Avatar
Car Info: 2004 WRX WR Blue Pearl
Question Making a GC8 top fit on a GDA
I searched and found nothing, just wanted to get that out of the way.
Well, as the title suggests, I am curious if a GC8 strut top mount can be modified to fit a GDA, or if I could just bolt up a GC8 strut top to a GDA. In the same line, would I be able to use a GDA strut top with a GC8 suspension? I'd like to find out as I am trying to save some money on a suspension kit and I found a nice coilover kit for hundreds less (for GC8) than the same kit for a GDA. Any help appreciated. Peace.
Al
AlBlueCar
Old Apr 9, 2004 | 12:03 PM
Z1 Performance's Avatar
they are interchangeable
Old Apr 9, 2004 | 12:16 PM
scoobsport98's Avatar
Car Info: 98 Impreza Outback Sport
just wondering, what coilovers are you talkin' about?
Old Apr 9, 2004 | 12:24 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
If the top mounts have camber adjustment, then they will not be working properly. The tops will bolt on, but the camber slits will be diagonal.
Old Apr 10, 2004 | 09:04 AM
AlBlueCar's Avatar
I don't wanna tell anyone what the set is, because I don't anyone to buy them out from under me, but they are veddy veddy nice
So camber adjustable= no work , but will a pillowball setup work (non camber Adjust)? Or should I just go with an STi Group N hard mount, or something like it?
Thanks for the help.
Al
AlBlueCar
Old Apr 10, 2004 | 08:41 PM
Uncle Scotty's Avatar
You COULD use the camber adjustement to give more CASTER which would ROCK.....
Old Apr 11, 2004 | 05:56 PM
AlBlueCar's Avatar
I'm all about caster, makes my car faster on the street races, just like my NOS....
SO, if it's camber adjustable up top, it will still bolt in OK, but the camber adjustment will be useless, correct? So, let's say I took a full coilover kit for a GC8 and it was camber adjustable, it will fit on my car correctly, although i will not be able to use the camber plates, right? I just want to make sure before i make an expensive mistake. Again, tanks for the help.
Al
AlBlueCar
Heedz
Feb 7, 2013 03:09 AM
nuclearfiziks
Feb 13, 2010 12:41 AM
scrWrx
Jul 23, 2005 12:40 PM
Rat
Jan 6, 2004 04:37 PM
PapaTroll
Nov 23, 2002 12:23 PM
