Help Me please sway bar help
Old Aug 14, 2006 | 08:30 PM
socalred's Avatar
+ + + Help Me PLZ + + +
I just installed cobb springs to my 05 sti. No others aftermarket suspension.
I go up an incline at an angle, which left the right rear dangling a second and it made the right rear sway bar flip down. The bar that connects the tip of the sway bar to the lateral link bar. I was told by the install guy to jack that side up and try to force it back up. I did but when i jacked it up the left side then popped down too. wtf. I then call my buddy with an 05 sti on tien flexes and he was surprised to find that his tiny little bar is actually broken. I assume his flipped and with use finally snapped. The drop on cobbs says 1.5 inch in the back but looks more like 1/2- 1 inch. How do i flip this bar so it's right again and how do I prevent this from happening every time I go over a bump. Has anyone had this problem?
Tell me how to post pix and ill show you all what it looks like.
Thx
Old Aug 14, 2006 | 08:43 PM
RedStage's Avatar
Car Info: Ver IV STi Wagon
how to post pics
upload the pic to the net, then use the tags [ img ] the insert the web address and end with [ /img ]
make sure there are no spaces after the brackets and letters surrounding img
Old Aug 14, 2006 | 08:59 PM
socalred's Avatar
there got the picture up. i jacked up both sides and tried to push into place with no luck.
Old Aug 14, 2006 | 10:23 PM
TheScoobyMedic's Avatar
Car Info: 05 wrx
what the repost, what happened to your other thread?
can you take a new pic from THIS angle?
Old Aug 14, 2006 | 10:26 PM
Car Info: 05 wrx
and i say what better time to buy some aftermarket end links
Old Aug 15, 2006 | 08:05 AM
socalred's Avatar
take picture from medial to lateral????
Will some cobb endlinks in the "U" shape help prevent this?
Old Aug 15, 2006 | 10:02 AM
excel's Avatar
Car Info: 04 STI
wow that's a first time seeing that for me
Old Aug 15, 2006 | 12:33 PM
bent sway bar link
Old Aug 15, 2006 | 10:15 PM
Car Info: 05 wrx
yeah i would like to see a picture from the side of this
and yes aftermarket end links should, theyre not plastic!! !!
Old Aug 16, 2006 | 03:31 PM
andyf's Avatar
Car Info: 2012 Mazda 3 Hatch
Your sway bar got "flipped." Some people have had it happen when they jack the car up on one end, or go up an incline at an angle, as you did. Majority of the time it is with the stock endlinks at stock ride height and a bigger sway, but not always.
Since you bent the endlink, you might as well pick up some aftermarket beefy ones... then you should be okay.
Old Aug 16, 2006 | 03:35 PM
andyf's Avatar
No, the U-shaped ones are for WRXs... ones for an STi are straight.
jung187
Oct 12, 2011 08:23 AM
sabrebluewhale
Jul 7, 2008 04:23 PM
DaFastOne
Jun 22, 2005 03:53 PM
Rat
Jun 5, 2005 11:04 PM
GottaREX
Feb 25, 2004 09:37 AM
