Help! Brakes
Old Aug 18, 2007 | 01:39 PM
03_Impreza_Al's Avatar
Help! Brakes
Alright posting this in here since theres more traffic.
Anyone got any tips to take off the front rotors?
I took off the caliper and put in the bolts on the rotors, but they won't budge at all...
Someone be my savior...
TIA
Old Aug 18, 2007 | 01:41 PM
darkonion's Avatar
Chicks dig me. April Fool's!
Hey Al.
Rubber mallet? or as Roo says BFH (Big F***ing Hammer).
I'll PM you my number, and if you need help, I can come by if I am not busy.
Old Aug 18, 2007 | 01:43 PM
flatline's Avatar
Car Info: Cage and Slicks and Wing OH MY!!
take off the calipers/caliper brackets, the rotors should come off pretty easily.
if not, use a rubber mallet like dark onion said.
Shouldnt be to hard at all
Old Aug 18, 2007 | 01:45 PM
wrxisthebest's Avatar
rubber mallet definately!!!!
but if thats not workin try some of that bolt losener stuff!
Old Aug 18, 2007 | 01:46 PM
i Got it yay..
si si puedo putos!
darkonion's Avatar
http://www.scoobymods.com/forums/sho...=&threadid=349
8mm screw/bolt thingy in the two holes in between the wheel studs. Check linky above.
Old Aug 18, 2007 | 02:10 PM
sweet i got it now i have new pads on the caliper and they don't go over the rotor how do i "open" it to clear it.
Old Aug 18, 2007 | 02:14 PM
kitsune713's Avatar
Car Info: '06 RBP Impreza 2.5i
You'll need a small c-clamp to disengage (push in) the caliper piston.
Karl
darkonion's Avatar
You'll need to compress/depress the pistons. Not sure how to do that, but I think you wedge something in there and yeah...
I am free right now if you need help. Give me a call and I can come by and help... even though you are in downtown SJ.
Old Aug 18, 2007 | 02:16 PM
kitsune713's Avatar
See below...
Old Aug 18, 2007 | 02:18 PM
darkonion's Avatar
Yeah. What Karl said.
Old Aug 18, 2007 | 02:22 PM
kitsune713's Avatar
Need one? I got one somewhere in the garage... I gotta hunt for it though!
Old Aug 18, 2007 | 02:23 PM
=\ i'll look for one...
Old Aug 18, 2007 | 02:24 PM
kitsune713's Avatar
I'll go look for mine now and check back if/when I find it.
Old Aug 18, 2007 | 02:27 PM
i found one its sorta working but hard to position it on the front calipers.
