Going to a larger rear swaybar will reduce understeer?
Old 09-14-2006, 09:09 PM
iceman302's Avatar
Car Info: 2005 WRX STI
I'm thinking of buying the Whiteline 24mm adjustable rear bar to go with my Prodrive springs and stock struts on my '05 STi. My goal here is to lessen or eliminate the nasty understeer that the car has from the factory. Has anyone had any experience with this combo?
iceman302 is offline
Old 09-14-2006, 09:11 PM
RussB's Avatar
Car Info: $200,000 sports car
a stiffer rear swaybar won't really reduce understeer as much as increase the tendancy for oversteer.
i'm sure sybir will chime in and correct me if i'm wrong.
RussB is offline
Old 09-14-2006, 09:12 PM
Warm Fuzzy Admin
sybir's Avatar
Nope, that's it.
sybir is offline
Old 09-14-2006, 09:15 PM
VRT MBasile's Avatar
care to elaborate on the difference between decreasing understeer and increasing oversteer?
VRT MBasile is offline
Old 09-14-2006, 09:20 PM
RussB's Avatar
reducing understeer means the front end gets more grip.
increasing oversteer means the rear end gets less grip.
the two can feel similar but are definitely not the same. reducing rear grip on a car that already has poor enough front grip to understeer can result in less overall grip and lower handling limits than before.
RussB is offline
Old 09-14-2006, 09:22 PM
that one legacy's Avatar
Car Info: 1995 Legacy L wgn & 1995 Legacy Brighton wgn
not only that, if you don't match with the right front sway (note, i'm not saying that the front sway you already have won't match well with this rear one that you're looking at), the tendancy towards oversteer can be pretty dramatic, and even outright dangerous! exactly how dramatic is determined largely by the difference in size between the two (there's other factors too though, especially with adjustable ones).
that's just the basic stuff though, this discussion could go WAY deeper than this.
that one legacy is offline
Old 09-14-2006, 09:23 PM
TitanSTI's Avatar
Car Info: Silver 09 STI
http://www.iwsti.com/forums/showthread.php?t=47158
http://www.iwsti.com/forums/showthread.php?t=26301
thatll help more than any of us trying to explain it to you.
i went with a whiteline 24mm adjustable bar up front and have the stock rear and the car is very neutral, it doesnt have the snap oversteer i would experience in my bugeye which had the stock front bar and aftermarket rear, which would still understeer BTW, until the rear end flew out. wasnt very confidence inpiring, LOL. on my STI the front end is planted and the rear just follows it, TONS of grip.
TitanSTI is offline
Old 09-14-2006, 09:24 PM
iceman302's Avatar
Explain. What is the best way to get the car to handle better and not push so badly?
Old 09-14-2006, 09:25 PM
To reduce understeer, you add front grip.
Kevin M is offline
Old 09-14-2006, 09:26 PM
iceman302's Avatar
So I'd be best off buying a matched pair.
TitanSTI's Avatar
exactly true.
and why i swear by a bigger front bar in the STI. a lot of people with stiff suspensions, like coilovers and such actually had to REDUCE the size of their rear bars for optimal handeling.
TitanSTI is offline
iceman302's Avatar
... and the best way to do that is?
Old 09-14-2006, 09:27 PM
TitanSTI's Avatar
read the 2 links i posted for you. they will sum it up perfectly.
TitanSTI is offline
Old 09-14-2006, 09:29 PM
iceman302's Avatar
Thanks, Justin. The Siegel Racing site was very informative.
Old 09-14-2006, 09:44 PM
Lots of ways. More camber, bigger and stickier tires, proper lowering, stiffer springs, stiffer front bar, front end weight reduction. You name it.
Kevin M is offline
Quick Reply: Going to a larger rear swaybar will reduce understeer?
