Front Suspension "Creeking" Sound? '03 WRX
Old Aug 1, 2003 | 12:08 PM
SpecWRX's Avatar
Car Info: 03 WRX 5sp
Cool Front Suspension "Creeking" Sound? '03 WRX
I have about 5,000 miles on my 2003
WRX, and notice a brief "creeking" noise
in the front suspension area when I start moving from a dead stop..
Also notice it when deaccelerating from low speed (5-10mph)...
Any of you guys have this sound on your cars?
Could it be some suspension bushing/part needs greasing?
I don't think it's clutch related since it creeks with the clutch already out...
the car is 100% stock for now....
Thanks!
Patrick
Santa Monica
Old Aug 7, 2003 | 06:24 PM
Salty's Avatar
forgive me but im a bit drunk at the moment:
I'm no super genius but if you're stopping in a straight line then it's probably not related to a sway bar and little greae.
do you have aftermarket struts? i guess it wouldn't hurt to look under your car and see if anything needs greasing.
I have an MY03 too and haven't had a problem.
knock on wood.
goodluck
Old Aug 20, 2003 | 04:00 PM
HellaDumb's Avatar
Car Info: 72 Vespa with curb feelers
Exclamation Ahahhaha--- Mine did the same thing
The mechanic fixed it... said it's caused by road-grime in the spring perch. Clean it off w/ compressed air or put some oil on that sucker!!
Old Sep 9, 2003 | 10:22 AM
SpecWRX's Avatar
Talking
Yep,
That's what SM Subie did as well after the tech localized the problem to a blown RT. strut.. too many damn potholes where I live!
They replaced both struts rickinep did, and it's not sqeakin...
Plan on lubing the spring perch as well just in case!!!
Patrick
Santa Monica, Ca
Old Sep 9, 2003 | 06:46 PM
SpecWRX's Avatar
Cool
I guess checking the strut integrity (and replacing bad struts like a few of us had done under warranty) as well as checking the spring perch for grime will be the best course of action against those dang annoying sqeaks!!
The car's almost perfect, so any suspension noise is noticable...
SpecWRX
