Front Cusco Sway Bar (Not your regular noise)
Old Mar 7, 2007 | 08:59 PM
strider327's Avatar
Car Info: 2005 WRX
So I just got a cobbtuning rear sway bar installed/Front cusco swaybar along with whiteline endlinks. No particular sounds except when I put the car in reverse it sounds like the front bar is rubbing or vibrating. All bolts are tighten down and bushings are greased...its only been 3 days. So i am assuming I have to let it settle in....but just like to know some feedback if anyone actually had this problem. Like I said there's no other noises over turns, bumps or anything just when I put the car into reverse and give it moderately a good amount of gas you can hear a rubbing sound.
Thanks in advance,
Calvin
JunGdB
26
May 9, 2006 01:07 PM
dropkick_muppet
Jul 16, 2005 12:13 PM
DaFastOne
Jun 22, 2005 03:53 PM
