driver side rear clunking when car is not under load
Old Dec 31, 2013 | 12:44 PM
esousa22's Avatar
Im getting a clunk when decelerating and under a very light load in my rear left. Lifted the car abd rotated the wheel and its clunking from inside the dustboot on the axle on the wheek side, not the differential side.
What could the clunking be exactly? What do I need to replace?
Old Jan 1, 2014 | 08:24 PM
esousa22's Avatar
bump
Old Jan 2, 2014 | 10:51 AM
Gancherov's Avatar
Car Info: 02 WRX Wagon
if its clunking inside the axle... replace the axle. It could also be the wheel bearing.
Old Jan 2, 2014 | 11:41 AM
esousa22's Avatar
thats the response I was looking for, thanks, much appreciated. After doing some research last night I narrowed it down to wheel bearing or axle but your response sealed the deal on that. Thanks!
Old Jan 20, 2014 | 01:12 PM
wgoike04's Avatar
Car Info: 04 Impreza WRX
If im getting a clunk on the passenger side in the front would that be differentials? or possibly just the axle and bearing?
Old Jan 20, 2014 | 01:20 PM
02RS25's Avatar
Check CV boot for tears. lift car and wiggle wheel at 10+ spots. Youll have your answer. unless you are running dramatically different tire and wheel sizes per side, diff should be fine. wheels bearings tend to wobble when unloaded and grind/clunk when loaded (i.e making a left turn and right side grinds, right side wheel bearing)
goodluck!
artex
Wanted
Feb 19, 2008 08:40 AM
wrxjrk
Nov 12, 2007 06:41 AM
1 fststi
Jul 29, 2006 03:50 AM
jimr
Dec 20, 2005 02:15 PM
UrbanAchiever
Oct 26, 2004 08:31 AM
