Difference between 04-05 WRX swaybars and 04-05 STi swaybars
Old Jun 4, 2005 | 04:26 PM
FromMugen2STI's Avatar
HI...i was wondering if anyone knew if there was a difference in size between the stock 04-05 swaybars for a WRX and the stock 04-05 swaybars from an STi
the same question applies for the endlinks
Also will the STi components fit onto the WRX and will it improve anything?
thanks for the help in advance!
Old Jun 4, 2005 | 07:22 PM
There is a small difference in size, but more importantly the STi uses a different style of endlink and swaybar design that makes it not transferable to non-STis. However, bugeye WRXs came with a 20mm rear sway bar that fits your car. You can find them cheap used.
lburrrna
May 5, 2007 09:53 AM
azn_ryder02
21
Jun 11, 2006 07:44 PM
amm2
Feb 13, 2006 12:58 PM
DizzyWRX
Apr 12, 2004 06:44 PM
