Cusco rear "V" brace help
Old Jun 27, 2004 | 03:57 PM
Damaged Goods's Avatar
Car Info: 04 wrx
Question Cusco rear "V" brace help
how do i install the rear v brace that connects the rear strut bar to the floor of the trunk?
do the bars go angled towards the front of the car or towards the rear of the car?
once i drill holes in the trunk how am i supposed to get the little plate with the bolts in it into position?
i hope somebody can give me a good explanation of how to fit this part in. TIA
oh, its a cusco brace in a 04 Wrx sedan
Old Jun 27, 2004 | 08:46 PM
Car Info: 04 wrx
ok, i get the top part, but how do i fit the bottom part on?
the bracket with the two bolts welded to it that goes underneath the car?
i cant see where this is supposed to go and line up with the piece on top of the trunk.
is there a bunch of stuff i need to take off the bottom of the car or am i just retarded and am doing this the complete wrong way?
Old Jun 27, 2004 | 08:59 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
IIRC, the bars are towards the front. I will check it tommorow on my car and let you know.
Old Jun 27, 2004 | 09:03 PM
Car Info: 04 wrx
thanks,
i dont suppose you know how to get that bottom piece on once i drill my holes? it sure looks like there is a lot of stuff in the way
Old Jun 27, 2004 | 10:47 PM
BLITZSTI's Avatar
Car Info: .
The bars that come down from the strut bar should be perpendicular to the car (there also should be stickers telling which one is left and right). the silver plate with the welded threads come from underneath the car. When you are under the car it fits snugly in front of the spare tire wheel well. Be careful when you plot the points for holes to be drilled as if you drill to close to the rear seats you drill into the steel reinforcement. I will post a pic of how mine looks...hope this is helpful
Quoc
Oct 30, 2006 08:39 AM
froggy
Aug 13, 2006 04:55 PM
Rat
Jun 1, 2006 10:11 PM
sabrebluewhale
Jul 31, 2005 07:56 AM
Mach5WRX
Apr 18, 2004 02:11 AM
