ABS light
Old Sep 20, 2012 | 10:50 AM
BlackSheep's Avatar
Car Info: 04 WRX 2.5 swap/91 Legacy GT
ABS light
The person that had the car before me put braided brake lines in and slotted rotors...and I not super mechanically inclined...yet...and cant figure out why the abs is having an issue. The light wont go off EXCEPT when i do hit the brakes hard i can feel it want to kick back and the light goes off but then comes back on within a minute
Old Sep 22, 2012 | 09:15 PM
04GG's Avatar
If in doubt, FLAT OUT
On one of my other cars, this meant either the fluid was low or the pads were worn out (worn out pads actually dropped the fluid enough to turn on the light) . Both fairly simple to check.
Old Sep 24, 2012 | 10:28 AM
BlackSheep's Avatar
slotted rotors,pads, and braided brake lines are new everything should be fine....
Old Sep 24, 2012 | 10:29 AM
esousa22's Avatar
have you tried to pull the code? Do you know how to pull the code by yourself with no equipment?
Old Sep 24, 2012 | 10:36 AM
BlackSheep's Avatar
I dont know how to do it without a code reader...both my abs light and airbag light are on and its not the fuses as far as i can tell
sadc
Jan 21, 2010 11:41 PM
imminence
Sep 30, 2003 12:16 PM
imminence
Sep 30, 2003 09:58 AM
GM6
Sep 22, 2003 11:12 AM
subiescottwrx
Feb 19, 2003 05:45 PM
