are 4 pot subaru brakes worth it
Old Nov 23, 2002 | 09:05 PM
stealth-wrx's Avatar
does anyone notice any drastic improvement in 4 pot brakes. also does anyone have the rear 2 pot brakes. any info would be great.
Old Nov 23, 2002 | 09:13 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Of course.
Expect a 7-12' improvement in braking from 60-0.
To run rear 2-pots, you need STi hubs, backing plates and axles, to run which you need a R180 rear end.
- Alex
Old Nov 23, 2002 | 09:31 PM
cool thanks
Old Nov 23, 2002 | 10:11 PM
ImprezaRSDriver's Avatar
I have the front 4pots and 2pot rears on my RS. I think the setup is great. But just a warning about the rears that it is pretty expensive to get those on. Quite a bit of dismantling of the rear is required. But definitely the front 4pots are worth it. The 2 pots are not needed as much.
Old Nov 23, 2002 | 10:21 PM
Thumbs up
good info. thanks
Old Nov 24, 2002 | 04:23 AM
Scubaru's Avatar
Car Info: MY02 GD WAGON, MY87 AW11
Just be prepared for the insane amounts of brake dust you WILL get from the pads that come with the 4pots. If your **** like me you will have to wash your front wheels frequently. But the feel and shorter stopping distances are worth it, trust me.
-scu
Old Nov 24, 2002 | 10:19 AM
Yeah, I know because I have them on my car
http://www.i-speedusa.com/images/whi...s_wrx_2pot.jpg
Old Nov 25, 2002 | 03:16 AM
go go go's Avatar
Car Info: GF8 ver6
I was thinking about the same thing.
4pots or not?
I decided to upgrade my rotors and pads instead.
I think it's more effective than running 4 pots with stock rotors and pads.
Pretty happy with how it ended up. (RG slitted rotors + AP Lockheed ZC pads)
If I had more funding, of course I'd love to do 4 pots (or GDB brembo) with performance rotors/pads.
Old Nov 25, 2002 | 03:21 AM
go go go's Avatar
Car Info: GF8 ver6
Originally posted by Kobayashi
[To run rear 2-pots, you need STi hubs, backing plates and axles, to run which you need a R180 rear end.]
However Subaru does now make an OEM application with the R160 rear assembly. The JDM model is called the NB-R Impreza WRX, it is also the UK and Euro WRX.
The latest "cross-eyed" JDM WRX are all 2pots rears too.
I don't really care about the backing plate though.
Old Nov 25, 2002 | 07:57 AM
FaLeX's Avatar
Originally posted by N/A
If you go to buy a set get then look on yahoo japan right now cause somebody is selling a set of Brembo 4 piston fronts and 2 piston rears for about $500. The usual 4 pistons run about $300 there as well.
Its a worth while upgrade.
can you PM me the link
