245/40/18 fitment issues.
Old May 1, 2013 | 05:47 AM
coastie87's Avatar
Car Info: 2006 WRX Wagon
Hello everyone, and thanks for reading. I need some advice/help in getting my tires to stop rubbing my inner wheel well. Surprisingly my rears do not rub, only the fronts do. Here is my current set up please give me some input on trying to get this to fit.
Wheels: 18x9.5 + 30
Tires: 245/40/18
Coilovers: Apexi N1
Camber: -1.75 in the rear stock up front (getting bolts for the front soon).
Height: unsure exactly sure how much lower it is, but the fenders hover about 1/4 inch over all 4 tires.
Fender work: Fronts are sedan fenders w/roll, rears are rolled and pulled.
I know getting a lower profile tire would fix the issue, but i'm saving that for my last resort because i just got the tires not too long ago. I was thinking possibly 5mm spacers all (still have some space) around and about and some negative camber would help.
Any thoughts and input would be greatly appreciated. Thanks agian.
Albee.
Old May 1, 2013 | 05:48 AM
coastie87's Avatar
my car is a 06 wagon btw.
Old May 1, 2013 | 05:55 AM
coastie87's Avatar
Ride height picture not the best but hope it helps.
Old May 1, 2013 | 05:57 AM
coastie87's Avatar
Old May 1, 2013 | 06:55 AM
awdorgtfo's Avatar
Car Info: 07 UGM WRX Wagon
How do you not rub in the rear? ****
Old May 1, 2013 | 07:29 AM
coastie87's Avatar
Beats me...might be because I have more inner wheel space.
Old May 1, 2013 | 07:58 AM
awdorgtfo's Avatar
Might have to take out the fender liner or cut it away in that area
Old May 1, 2013 | 08:07 AM
04caliwrx's Avatar
should be on 245/35/18
Old May 1, 2013 | 08:12 AM
LOL_VTEC's Avatar
Car Info: 2018 Tacoma TRD PRO
Should do the 5mm spacer route. Nice rims btw
Old May 1, 2013 | 08:28 AM
coastie87's Avatar
Wish I thought of that/ did the research before I bought the tires lol
Old May 1, 2013 | 08:29 AM
coastie87's Avatar
Already took it out....its rubbing the actual wheel well...paints been polished clean now I have to primer it so it doesn't start rusting.
Old May 1, 2013 | 08:30 AM
LOL_VTEC's Avatar
I think the side wall would be to skinny looking. The tires you have on now look fine. Just get a 5mm spacer up front
Old May 1, 2013 | 08:32 AM
coastie87's Avatar
Thanks. I may have to do that. But from the looks of it I might even have to do a 10mm spacer 5 doesn't look like it'll do the job.
Old May 1, 2013 | 08:45 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
i rub like crazy in my rear on harsh bumps ..i own a 05 tho. on 245 40 18
Old May 1, 2013 | 08:50 AM
coastie87's Avatar
Give you guys an idea of how much space I got still
Picture on the left is the rear driver side, and the one on the right is front driver side.
Attached Thumbnails 245/40/18 fitment issues.-forumrunner_20130501_084958.jpg   245/40/18 fitment issues.-forumrunner_20130501_085025.jpg
