2006 wrx rear sway bar HELP!
Old Jun 20, 2007 | 09:02 AM
rex408's Avatar
Car Info: 2006 WRB
I'm going to buy a aftermarket sway bar for my 2006 rex. Just want to know that would it work with the stock endlinks? Like i was looking at whiteline 24mm sway bar. Thanks
Old Jun 20, 2007 | 11:32 AM
Frestall's Avatar
Car Info: 2006 WRX TR
I had my progress one on stock endlinks, but switched that up pretty quick. The stock endlinks looked like garbage to me, justified the cost of some endlinks as soon as I did the install. They should work fine, the only real problem with the 06-07 is the difference in the exhaust bends and making sure it doesn't tap on the gastank... I had to go to the stiffest setting to make sure mine fit.
Old Jun 22, 2007 | 10:21 PM
cowg's Avatar
Car Info: 07 subaru wrx
07 wrx-I ditched the bridgestones for michelin pilot sport PS2's-big difference but turn in still sloppy. Put a set of cobb front and rear sway bars on-UNBELIEVABLE. I actually got pissed cause the factory should of done something like this stock. Don't just buy the rears the car needs both.My local perf shop, IA,strongly recomended these and they were right. $350 for both.You need a lift to keep the job from being a real pain and a bit of grinding was necessary on the evap can hanger. But I just can't describe how improved the car is.
Old Jun 22, 2007 | 11:10 PM
cowg's Avatar
ps. sorry I forgot to say virtually all bars work with the stock links-In questioning many sources I only found one verifiable instance of a guy bending the rear factory links and that was in autox with some sticky's on. The links are nice but you'll spend $200-300 on a set of 4. It won't hurt anything if they get bent or worse and you'll know it's time to spend the extra bucks.
Old Jun 26, 2007 | 10:33 AM
trentonlatrell's Avatar
Car Info: 2006 WRX
$100 isn't much to spend on unbreakable Kartboy rear endlinks. i have them with my 24mm whiteline rsb.
Old Jun 26, 2007 | 10:34 AM
SubyN00by's Avatar
the stock endlinks with a 24mm sway will eventually break, just be safe and bust a set
flatline
Jan 21, 2007 04:49 PM
jc0019
Oct 7, 2005 07:53 PM
Rat
Jun 5, 2005 11:04 PM
GottaREX
Feb 25, 2004 09:37 AM
