04 wrx OEM struts blown at low mileage?
Old Apr 9, 2007 | 11:39 AM
strider327's Avatar
Car Info: 2005 WRX
04 wrx OEM struts blown at low mileage? UPDATE FIXED!
Is it normal for 04 wrx's OEM struts to blow out at around 30K miles, especially the rear struts? I have been reading a lot on how the STI rear struts are defective but haven't seen much on the actual WRX line of the OEM struts being defective..so I am wondering if this is normal or not. My only mods on my suspension is front/rear sway bars and endlinks nothing else. Any advice or recommendations are appreciated. If I do need to replace them I might as well upgrade so to speak. I was thinking of Prodrive springs and some aftermarket struts but dunno which one to get. I want something that's more into not to stiff but then at the same time will not create any weird noises.
Old Apr 12, 2007 | 05:26 PM
strider327's Avatar
Car Info: 2005 WRX
So today I tooked out my rear seats and started unbolting and retorquing all the bolts and found out the tubular (Grey Bar) and the Black T-Bar behind the rear seats were slightly loose. I retighten all the bolts I could find and BAM no more noise. I would just suggest the guys having this clunking sound to try this step before replacing anything and check those endlink bolts as well. Good Luck it worked for me.
Shaitiger
Sep 11, 2003 05:30 PM
Shaitiger
Apr 8, 2003 10:00 PM
Shaitiger
Wanted
Apr 6, 2003 09:31 PM
Shaitiger
Apr 2, 2003 12:09 AM
Shaitiger
Mar 30, 2003 11:22 PM
