Poltech Rear End Link SUSPENSION SYSTEM UPGRADE
Car Info: 03 Evo, 88 RX-7 T2
Rear End-Links - Adjustable: 149.00 Shipped
Model: '00+ RS, L, '02+ WRX, and '95-'00 Legacy
-Direct replacement for stock plastic links offers exceptional strength and stiffness, suitable even for the most demanding racing applications
-Improve responsivness and sway bar efficiency, they feature stiff polyurethane bushings
-Anodized billet Aluminum 6061 constructions ensures that the links will not deform like the stock plastic units further increasing the response of your suspension
-Includes new hardware and installation instructions
-Improves vehicle handling (makes it more neutral and reduces roll) by reducing the play caused by the stock rubber bushings, helps make your car handle like it should
-Allows for length adjustment to eliminate sway bar preload (helps level the vehicle), a must for cars with coilovers, each millimeter of misalignment between the right and left side of the 24 mm sway bar generates 6kg (12 lbs or 320 lbs/inch) of unbalanced force effectively raising one side of your car, thus your car is no longer leveled. Those links can eliminate up to .5 inches of misalignment
-Or you may use them to raise one side of your car using just the sway bar, the choice is yours
Rear End-Links - Heavy Duty: 99.00 Shipped
Model:'00+ RS, L, '02+ WRX, and '95-'00 Legacy
-Unlike the links with bushing offered by other manufacturers, our bearings COMPLTELLY eliminate play between the sway bar (anti-roll bar) and control arm for instantaneous response of your suspension without a noticeable increase of vibrations and harshness
-Features spherical bearings with Teflon™ lining for superior response and durability, self lubricating for lifetime of quiet operation
-Bearings are sealed for additional protection
-Spherical bearings allow for resistance free pivoting unlike links with rubber bushings that subject the sway bar and suspension to sideways loads
-Improves vehicle handling (makes it more neutral and reduces roll) by eliminating the play caused by the stock rubber bushings, helps make your car handle like it should
Rear End-Links - Heavy Duty, Combination: 99.00 Shipped
-Designed for those that want to minimize added vibrations and harshness yet still want the performance of solid end links, this product offers almost the same performance as our products above but features a polyurethane bushing on one side to dampen the vibration and spherical bearings on the other to reduce the side loads on the sway bar
Rear End-Links - Adjustable: 99.00 Shipped
Model: '04+ STi, '05+ Legacy GT, and '05+ Forester
-Direct replacement for stock links offers exceptional strength and stiffness, suitable even for the most demanding racing applications, must for aftermarket sway bars
-Plated steel constructions ensures that the links will not deform like the stock units and will resist rust and corrosion
Spherical bearings allow for resistance free pivoting thus increasing effectiness of your sway bar
-Allows for length adjustment to eliminate sway bar preload to improve car's handling (helps level the vehicle), a must for cars with coilovers, each millimeter of misalignment between the right and left side of the 24 mm sway bar generates 6kg (12 lbs or 320 lbs/inch) of unbalanced force effectively raising one side of your car, thus your car is no longer leveled. Those links can eliminate up to .5 inches of misalignment
500whp.com
Feb 3, 2006 11:00 PM
500whp.com
Feb 2, 2006 06:41 PM
jimtweet
Jul 19, 2005 05:57 AM
