Intro: DBA Brake Rotors One Piece and 2 Piece!
Old Sep 26, 2005 | 02:51 PM
500whp.com's Avatar
Car Info: 03 Evo, 88 RX-7 T2
Talking Intro: DBA Brake Rotors One Piece and 2 Piece!
DBA announces the most significant breakthrough in disc brake rotor design for decades.
The new DBA Kangaroo Paw delivers significantly improved braking performance. Even under extreme braking conditions.
The innovative Kangaroo Paw design runs cooler, is stronger, and outperforms traditional straight vane disc rotors.
So what makes it so good?
A car’s braking system is one of the most critical areas in terms of vehicle safety and performance. Being able to stop safely and reliably, time after time, under heavy braking conditions can mean life or death.
Every time the brakes are applied massive pressure is built up through the braking system. A 35Kg force applied at the brake pedal is multiplied hundreds of times before being applied at the disc rotors, creating friction and extreme heat.
Traditional Straight Vane
The extreme heat can cause disc rotors to warp, distort and in some cases fail. Traditionally, heat is removed as air flows through the rotor passing between straight ‘vanes’.
However, the straight vane design does not provide the ideal conditions for heat to be dissipated and tends to create an unwanted ballooning effect.
DBA Kangaroo Paw Vane
The Kangaroo Paw features 144 precisely positioned diamond and tear-drop pillars. More than just making the disc stronger, the pillars provide a greater surface area than traditional straight vane designs. Greater surface area means more effective heat dissipation and cooler running disc rotors. The Kangaroo Paw disc rotors will quickly remove the heat, cool the discs, and return to optimal operating temperatures ready for the next braking application.
Cool air flows in from the centre of the disc, while hot air is forced to the outside of the disc - regardless of rotational direction. The pillars provide greater strength across the disc rotor and reduce the tendency for disc distortion.
More efficient cooling improves brake pad and disc rotor life, and helps reduce brake fade.
DBA 'Heat-Sensitive' markings
on DBA 4000 & 5000 series disc rotors.
Heat-Sensitive’ markings are placed on the outer edge of a disc rotor and are used to monitor the core temperatures that are achieved during braking application.
NOW AVAILABLE:
4000 Series (1 Piece):
WRX 02+
Front/Rear: Standard (no slots), Slotted, Cross Drill/Slotted (Not recommended for Racing) - 220.00 Shipped (front Set or rear Set)
Front/Rear Gold Hat: Standard (no slots), Slotted, Cross Drill/Slotted (Not recommended for Racing) - 245.00 Shipped (front Set or rear Set)
STi 03-04
Front/Rear: Standard (no slots), Slotted, Cross Drill/Slotted (Not recommended for Racing) - 350.00 Shipped (front Set or rear Set)
Front/Rear Gold Hat: Standard (no slots), Slotted, Cross Drill/Slotted (Not recommended for Racing) - 370.00 Shipped (front Set or rear Set)
STi 05
Legacy GT 2005
Front/Rear: Standard (no slots), Slotted, Cross Drill/Slotted (Not recommended for Racing) - 260.00 Shipped (front set or rear set)
Front/Rear: Gold Hat (no slots), Slotted, Cross Drill/Slotted (Not recommended for Racing) - 280.00 Shipped (front set or rear set)
5000 Series (2 Piece):
WRX 02+
Front Black Hat: Slotted, Cross Drill/Slotted (Not recommend for Racing) - 540.00 Shipped Front Set
Front Gold Hat: Slotted, Cross Drill/Slotted (Not recommend for Racing) - 560.00 Shipped Front Set
STi 03-04
Front Black Hat: Slotted, Cross Drill/Slotted - 720.00 Shipped Front Set
Front Gold Hat: Slotted, Cross Drill/Slotted - 740.00 Shipped Front Set
STi 05
Legacy GT 2005
All Cross Drill w/ Slotted rotors are Not recommend for Racing
Old Sep 26, 2005 | 03:22 PM
500whp.com's Avatar
prices updated
Old Sep 26, 2005 | 04:02 PM
500whp.com's Avatar
4000 Series:
5000 Series:
Old Sep 29, 2005 | 11:00 PM
zumnwrx's Avatar
WRX 02+
Front/Rear: Standard (no slots), Slotted, Cross Drill/Slotted (Not recommended for Racing) - 121.00 Shipped (front or rear)
Front/Rear Gold Hat: Standard (no slots), Slotted, Cross Drill/Slotted (Not recommended for Racing) - 131.00 Shipped (front or rear)
im looking for 4000 slotted dba whats the difference between the gold hat and standard?
im thinking its just the gold color am i right?
edgar,
Old Sep 30, 2005 | 04:47 AM
Egan's Avatar
Why are the 5000 series "not recommended for racing"? Why else would I run $700 2 piece rotors on my STi?
Old Sep 30, 2005 | 11:08 AM
EndlessWaltz RS's Avatar
Car Info: 00 BRP RS LIC'd 01 EJ207 + non DCCD 6 Speed
I too was wondering this...??
Old Sep 30, 2005 | 11:16 AM
Egan's Avatar
I'm especially curious since I already have two track days on mine.
Old Sep 30, 2005 | 12:12 PM
Roo's Avatar
Roo
Forester Specialist
Car Info: '98/'04 Foresters (S & XT)
On the 5000 series gold hats, are the hats actually made of gold?
at $7400.00, I'd expect them to be...
Old Sep 30, 2005 | 12:22 PM
LozSTi's Avatar
Car Info: 05 STi WRB
Cross drilled rotors are not recommended for racing, they look cool but that's about it. There are tons of posts about that on this forum. I think that's what the vendor means.
Old Sep 30, 2005 | 12:36 PM
SubyFi's Avatar
Car Info: 2005 WRX STi
How much is a replacement rotor (w/o the center hat) for the 5000 2 piece model for a 2005 STi?
Old Sep 30, 2005 | 01:11 PM
500whp.com's Avatar
edgar,
YES just color =)
Old Sep 30, 2005 | 01:14 PM
500whp.com's Avatar
Because all Cross/drilled rotors tend to crack under extreme heat! Most race cars will run slotted rotors, some might be like 20 + slots, but no drilled!
Think of it as if you are strong enough to brake the rotors w/ your hand. But the rotors are build to well, so u drilled holes in the rotor making the rotor itself weaker and intern you broke the rotor!
500whp.com's Avatar
Talking
GOLD COLOR =)
Old Sep 30, 2005 | 01:15 PM
500whp.com's Avatar
Thumbs up
Replacements are 162.00 ea!
Jeffrey
Old Sep 30, 2005 | 03:00 PM
Egan's Avatar
I realize that, but the post was not clear if the "not recommended for racing" was for just the cross drilled/slotted or the slotted ones as well. The wording could scare away potential customers.
As a testimonial, my DBA slotted rotors have held up well so far. They're on an 04 STi with Ferodo DS2500 pads.
