(what weight) engine oil (for EJ20?)
Old Nov 1, 2008 | 12:38 PM
wagoneeer's Avatar
Car Info: 2002 wrx wagon
what weight does an ej20 run...my owners manual got jacked and just got the car and dont know what weight it is?
Old Nov 1, 2008 | 12:42 PM
Irish_car_B0mb's Avatar
probably 5w30 thats what SOA recommends for everything
Old Nov 1, 2008 | 02:39 PM
wagoneeer's Avatar
y thank you fine sir
Old Nov 1, 2008 | 02:56 PM
wrxisthebest's Avatar
yes, 5w-30 is the subaru recommended oil.
it should also tell u on the oil fill cap!
Old Nov 2, 2008 | 10:59 AM
wagoneeer's Avatar
yeat thats what i thought too, but it says see owners manual, which i dont have. so i was sol
Old Nov 2, 2008 | 11:36 AM
damm that sucks... well just remember the 5w-30
i run 10w-30 during the summer due to hotter weather, but durring the winter i use 5w-30
Old Nov 4, 2008 | 04:47 PM
wagoneeer's Avatar
word, thanks man
Old Nov 19, 2008 | 06:06 PM
STi-owns-evo's Avatar
Car Info: '02 PSM WRX
IMHO, 5W-30 is too thin for Subarus. I find even 10W-30 thin as well. Subaru recommends 5W-30 to get the best gas mileage, while I'd rather have a small hit in gas mileage for the added protection of my motor.
Many people love Mobil1, which tends to run thin, so you're already running a thin 5W-30 with a thinner 5W-30 Mobil1 than other same rated oils. I just did the same thing as everyone else, until my motor blew. After that, I did my research, and talked to a few shops. Overall, I found most shops also don't recommend using 5W-30, nor do they recommend using synthetic oil (as that runs thinner as other same rated oil weights as well). You'll find if you ask around, a lot of people are adding a quart of oil ever 1k miles!
While I may be running a much thicker oil than what other people recommended, in using Rotella-T 15W-40 oil, I have never had to add a drop of oil between oil changes, and it's specifically built for Turbo Diesels (to me, a plus, since we're running turbos) while passing all the tests for normal unleaded engines.
Just my .02
chakming888
Oct 31, 2010 10:20 PM
bluebiker
Jun 22, 2006 10:41 AM
Dm0n3y002
Nov 15, 2004 03:07 AM
wrxless
16
Apr 27, 2004 08:39 AM
