STI pulling to the Right HELP!
Old Oct 15, 2004 | 06:04 PM
duo's Avatar
duo
Car Info: WRB WRX 2004
i had that same problem with my new wrx...just put more air in the right side tire..see ifthat helps thats what i did andit fixed it hope that helps
Old Oct 15, 2004 | 08:04 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Check the tire pressures and make sure they are set correctly. BTW adjusting the tire pressures so they are uneven just to correct a pull is a bad idea and is only masking a problem that needs to be repaired.
If the tire pressures are ok, and you are able to do so, try swapping the tires side-to-side. If the problem is tire-related it should then pull to the opposite side. If unchanged, look carefully for any unrepaired suspension damage such as bent control arms etc. Even if the car wasn't in an accident, it's possible that when it was stolen the wheels might have been taken, and the car then dropped or dragged on the suspension causing some damage.
It's too bad you are under a tight time constraint to purchase this car, because some more time may be required to fully evaluate its condition and determine whether there are any serious underlying problems that would affect your purchase decision or at least affect the price. Good luck.
Old Oct 15, 2004 | 10:04 PM
Rocket Man's Avatar
Car Info: it's nice
hey Nuke.
This is very common on the 04s (one of the many imporovements on the 05s).
Subaru should honor an alignment. That's all you need. You may even notice the sterring wheel isn't exactly lined up when you drive straight too.
Old Oct 16, 2004 | 04:38 AM
Mulder's Avatar
In this case Subaru may not honor the warranty since the car is a recovered theft, so he needs to be very careful to evaluate it before the purchase.
az1muth
Aug 8, 2014 12:26 PM
ridetillurdead
Nov 15, 2010 12:19 PM
Cynt
Aug 13, 2007 02:27 PM
zphreak
Aug 6, 2007 05:23 AM
