Power Steering '?'
Old Apr 11, 2007 | 07:46 AM
grambo's Avatar
Car Info: '06 CGM STI
Power Steering '?'
Installed a new power steering reservoir. Installed the proper fluid. Checked the levevl twice and its cool. My pump is now making noise. (Or I am hyper sensitive to it because of the install.) No lines are crimped, nothing is leaking.
Any other guys have a semi-noisy pump?
Old Apr 30, 2007 | 06:31 PM
Laneman123's Avatar
Car Info: Subaru WRX, 2004
Power steering
You have to bleed the air of the system. Leave the cap off the reservoir and turn the steering wheel lock to lock several times with the engine on. If you still see air bubbles or if the fluid seams foamy shut the engine off and let it sit for like 5 minutes or so and repete the procedure. This should get the air out and your pump should stop making the noise. Unless the pump is bad.
dyepball1
May 18, 2006 10:23 AM
SSFWRX
Dec 30, 2005 01:36 AM
I3eXa
Mar 7, 2005 08:01 AM
TheREAL HiFiWRX
Oct 22, 2004 03:55 PM
MilkManX
Mar 30, 2004 10:42 AM
