Oil Light Question...
Old Sep 4, 2008 | 10:24 AM
Speeding101's Avatar
Car Info: gone
So i recently was in an accident with my WRX... I HIT A DEER.... and it pushed my upper radiator support bar into my pullies and tore a hole in my radiator hose... while like a dummy i checked oil and radiator fluid and decided that i really wanted to get it home that night without a tow-truck and put more oil in it when it was not needed.... so i ran it home nearly over-heating with too much oil and got it home... i fixed everything drained my oil and radiator, flushed it all and now i have a problem... my oil light is on but very very faintly. almost to the point to where you can't see it... I am not leaking oil lanywhere and i am burning quite a bit of it.... and suggestions as to whaat it is?
Old Sep 4, 2008 | 11:54 PM
Car Info: gone
bump... need help
Old Sep 4, 2008 | 11:57 PM
stirs's Avatar
Car Info: 2000 2 door RS/ daily driver vtech
check all oils on the car for levels...if not replace the oil presure sensor
Old Sep 5, 2008 | 12:01 AM
wrxisthebest's Avatar
stop using crappy *** castrol is my idea.. lol
Old Sep 5, 2008 | 12:04 AM
Car Info: gone
i don't think castro is crappy... it works good in every car... lol...
Old Sep 5, 2008 | 12:06 AM
lol...
well is it recommended by Subaru? noooooo......
so thats y i say crrrrrappppppyyyy... lol
nah it can't be it, cause people run non synthetic(stupid bastards)
hmm.. ur burning alot of oil?
maybe ur turbo cause of that fluttering???
Old Sep 5, 2008 | 12:11 AM
Car Info: gone
thats what i was thinking... but why now is it coming out? i didn't have a problem before with the fluttering... why would it be eating so much oil... so... idk...
Old Sep 5, 2008 | 12:13 AM
are u sure it wasn't eating oil before???
100%
hmm...
well u need to replace the turbo anyways...
the only thing i can think of is that while ur car was parked ur turbo seals dried up or something.. blown seals...
which suck.
easy way to see, let ur car idle warm up on a hot day until it is at hot almost, then hit the gas, if u get blue smoke out of ur exhaust, ur seals are ****ed!
Old Sep 5, 2008 | 12:15 AM
Car Info: gone
yeah well i don't think it is my seals... but it could be possible...
Old Sep 6, 2008 | 09:13 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Most likely there is some coolant residue on the oil sensor and wiring, and it's conductive enough to allow a small current to flow to ground which will illuminate the oil light dimly. The light is an LED and it doesn't take much current to light it visibly.
Clean the sensor, wiring and surrounding area thoroughly and the problem should go away.
Old Sep 6, 2008 | 09:42 PM
Car Info: gone
wow... ok... that was a more detailed explination than i was expecting... but i will try that immediately and see if it shows up... let you know when i do it...
Old Sep 6, 2008 | 11:48 PM
Wingless Wonder's Avatar
I think the oil indicator lamp and your oil consumption are two unrelated problems. If your car isn't leaking oil, then it's either going into the coolant or burned up in the exhaust. I think it can be diagnosed by a experienced shop using a leakdown tester (not a compression gauge), but of course a technician may be able to spot something that we can't see online.
A leakdown test can only diagnose problems originating in the engine block or cylinder heads - if the turbo developed a leak with an internal seal, this wouldn't show up.
Old Sep 6, 2008 | 11:56 PM
leak down( air forced into the cylinder)
compression(pressure built by the piston itself)
Old Sep 7, 2008 | 09:10 PM
Car Info: gone
yes thank you ryan... i understood that one
Old Sep 9, 2008 | 10:40 AM
Hardware89's Avatar
Car Info: 91 Legacy Turbo
i know how to fix it....dont hit deer
