Where is the fuel level sensor located?
Old Sep 9, 2003 | 08:53 AM
wvjnky's Avatar
Car Info: 02' Black Wgn
My fuel gauge is all jacked up so I baught a new level sensor. I got the scematic from subaru but it shows two sensors that look very much alike. Question : where is the fuel level sensor located? How do I get to it to replace it? I own a 02" wrx wagon. There isn't a tech. forum to handel this one, so I am depending on you guys.
Old Sep 9, 2003 | 10:49 AM
wvjnky's Avatar
thanks
of the two sending units. Do you have any idea which one would be the main sending unit? I am looking for the one that controlls the gauge. Thanks for your help.
Old Sep 11, 2003 | 09:30 PM
SUBARU_TECH's Avatar
its on the passenger side of tank-plz do some ohm readings -voltage test before you keep throwing parts at it.if you insist on fixing it urself-vist ur local suba dealer and ask te tech to print of the diagnoisis work sheet for this problem
Old Sep 12, 2003 | 12:15 PM
wvjnky's Avatar
unfortunatly
ever since I brought up the TSB on the clutch shudder I am treated like a seconclass citizen at my local dealer. It was like pulling freakn' teeth to get the guys to print off a schematic of the tank. Then I noticed the two level indicators that looked the same and the guy said, Uh....I don't know....then didn't offer any other help. I would rather beat my head repeatedly with a hammer before I would trust my car car to these guys. But anyway, as far as you know, could there be any other part malfunctioning that would cause the false reading on the gauge? The gauge will register full then show empty at 9.5-10 gallons.
Old Sep 12, 2003 | 09:14 PM
first-next time you vist your dealer ask what there (soli) score is for there area-this will give you a idea on what other customers think of the overall work and service from that dealer.you can use this to base the better shop in ur area.agian i get upset myself when everone comes in now knowing that there is a improved flywheel,plate and disc to fix clutch shudder,people come in by the the hordes with this info,so you have to first verify that it does happen before any repairs are to be done,or else everyone will be coming in for it.yes there is some easy test to do-if you are familar with electrica and can you use a muti meter then i would be happy to send you the diag sheets on this.the specs for measuring the level sensors are at the full down and up positions,resistance values will need to be checked-one time i had a bad circuit board in a instrument cluster which caused the problem in a outback,which was caused by the customer.this is why i stating that more time testing the cicuit is worth its weight in parts thrown at it.please e-mail me ur year and model of impreza and i be happy to send you the print out
Old Sep 15, 2003 | 12:28 PM
wvjnky's Avatar
Thanks for your help!
Well, buy the time I made the first post I had allready purchased the level indicator. This weekend I threw the part in and guess what, no change in the performance of the gauge. I should have taken your advice. So this is where I am at. It isn't the in tank level indicator. I own a 2002 impreza wrx wagon. If you could fax me any info on the electrical it would be greatly appreciated. Fax # 1-800-465-8366.
Thanks,
Josh
Old Sep 15, 2003 | 03:07 PM
will due this tuesday the 16th.
Old Sep 17, 2003 | 01:03 PM
wvjnky's Avatar
any update on the info for my malfunctioning feul gauge?
Old Sep 17, 2003 | 05:13 PM
have the info-could use a e-mail thou.you will need adobe reader.free download at there site.i assume your car is over 36k miles,right.do you no how to use a multi-meter.if so send me your e-mail so i can send ya the info.
Old Sep 18, 2003 | 08:17 AM
wvjnky's Avatar
josh@niterider.com
The car has 51K..
Thanks for the help
Old Sep 18, 2003 | 06:00 PM
the file is to big to download.im trying to find a way thru adobe to just copy the pages needed to send ya
Heedz
Dec 8, 2014 09:49 AM
EK
May 26, 2013 01:43 AM
Imprezer
Sep 25, 2003 04:16 PM
etal
May 29, 2003 10:58 AM
EvoEater
Apr 1, 2003 09:18 PM
