turn signal kills cluster
Car Info: '05 Legacy GT Wagon
just picked up a 2000 outback that has an interesting elec. problem , the entire cluster works intermittently , if i flick the key off and on a half dozen times i can get it work but 100% of the time if i use the turn signal it kills the cluster, temp, tach, speedo, everything turns off while the car continues to run and drive normally , while the cluster is dead the radio and ac/heat work normally, sometimes it turns back on while driving , other times i have to turn the car off and do the key flick on/off thing a few times , when the cluster does come on while driving all the idiot lights that normally illuminate when you first start the car turn on for a few seconds and then go out like they should
i'm not sure if i am dealing with a ground problem, a bad ignition switch, bad turn signal hdlt combo switch, or all of the above , i can turn a wrench pretty well but electrical problems boggle me so any thoughts/help is appreciated !
Car Info: 2002 BRP 2.5RS
The turn signal is a short. You need a voltometer and to try different + feeds with a ground. Turn on the signals and see where the current is killed.
The entire dash not working is probably just a power short at the ignition in the steering column.
Where in NorCal are you?
update today fwiw, unplugging the turn signal hdlt switch results in the cluster working 100% of the time, does anyone have a wiring diagram for the main harness that plugs into that switch ?
i'll look at it more tomorrow, forgot to add the turn signals work like they should when the hazard switch is depressed , perhaps even more proof that the problem is inside the car between column and cluster
SlickmisterN
Mar 15, 2019 04:06 PM
kenchan
Jul 23, 2003 12:42 PM
