Quick question about fuel injectors.
Old Feb 10, 2015 | 09:10 AM
Sufabru's Avatar
Car Info: 1998 Impreza L
I had a cylinder 2 misfire. I changed everything from spark plugs to coil packs without much result. I decided to switched the fuel injector from cylinder number 2 to cylinder number 1. The code went from cylinder number 2 to cylinder number 1.
So I went and got a new fuel injector. I installed it to cylinder number 1 and when I started it the code went back to cylinder number 2.
What's happening?
Old Mar 4, 2015 | 12:53 PM
partywagon42's Avatar
Any luck?
Old Mar 11, 2015 | 12:51 AM
Sufabru's Avatar
Originally Posted by partywagon42
Any luck?
I guess fuel injection was fine. One of the cylinder where the supposedly bad fuel injection has zero compression.
Old Mar 25, 2015 | 02:24 PM
Just realized that was you in the other thread. Did you decide whether to pull the engine?
Old Mar 25, 2015 | 03:36 PM
NorCalPaintball's Avatar
Car Info: '12 FXT Touring
Ringland?
Old Apr 13, 2015 | 01:19 PM
Sufabru's Avatar
I didn't pull the engine. That was my plan but I decided to do it without pulling the engine.
The exhaust valve on the cylinder that has zero compression is bent.
I bought a new timing belt and a new timing belt tensioner hoping that would solve the problem before but now that I know it's a bent valve I'm scared to reuse the timing belt and timing belt tensioner that I just recently bought.
Should I just but a new timing belt and a new timing belt tensioner just to be sure?
Old Apr 13, 2015 | 01:20 PM
Sufabru's Avatar
Originally Posted by NorCalPaintball
Ringland?
Not really sure about the ring land. I'm not familiar with that one yet but I can see the exhaust valve on the cylinder that has zero compression is definitely bent.
Old Apr 13, 2015 | 01:26 PM
Sufabru's Avatar
After the bent exhaust valve every time I put the timing belt together and start the car it always skip timing. Can a bent exhaust valve cause the timing belt to skip or there's something wrong with the pulleys, the timing belt, or the timing belt tensioner?
I'm afraid that once I have the bent exhaust valve fixed that reusing the timing belt and the timing belt tensioner that I recently bought and used during the process of finding out what's wrong will bend the valves again.
The belt and and the tensioner has pretty much zero miles but I'm having doubts. I feel like buying another brand new belt and tensioner but I'm thinking about the wasted money as well if that's not even the cause of the belt skipping.
808subaru
Oct 16, 2008 10:22 PM
HitMan912
Mar 5, 2007 04:32 PM
JohnB
Jun 30, 2003 12:14 PM
skylinesf
May 2, 2003 04:49 PM
