Hit 1000 miles. Shoud I change my oil?
Old Jun 2, 2003 | 05:20 PM
mysubaruimp's Avatar
Car Info: 2001 sub. imp.
i would replace it at 1000 for the first time. call your dealership and ask if no one on here can answer
Old Jun 2, 2003 | 05:38 PM
ish's Avatar
ish
sure as heck doesn't hurt, generally why people say to change it after the first 1000 is because your engine since it is brand new will let go of various pieces of metal and what not and changing it early just gets rid of that sooner. but i haven't seen any proof that it is better to change it earlier
Old Jun 2, 2003 | 09:38 PM
The special break-in oil is a myth- it's just standrad 10W30 dino- but even if it were, his car is already broken in. Changing it never hurst, but to be honest, you'd probably be fine with another 5k or so. I change mine every 2500 or so, but it takes me more than 3 months to rack up that many miles. I also use full synth, which is god for 7-10k miles anyway in a modern engine like ours.
Old Jun 5, 2003 | 10:17 AM
Dtech's Avatar
Car Info: 2004 Platinum Silver WRX
Definitely a synthetic myth. The Owner's Manual of my new 2004 WRX says that the use of synthetic is fine as long as it's the same grade and certification as the dino oil specifications.
Old Jun 5, 2003 | 10:35 AM
Br1t1shguy's Avatar
Car Info: 02' WRX
go ahead
It is typiclly a good idea to change the oil after the 1000 mile break in. There are a few reasons for this, but the most important is that, as any engine builder will tell you, the first 1000 miles are the most important to piston ring sealing. This is because for the first hundred miles the piston rings are at their roughest, and the crosshatching is at its most agressive. While there is hardly going to be a cm thick layer of metical particles in you're oilpan or anything, the oil will contain more abrasives after the first 1000 miles than probably any other time in its lifetime. So usually its a good idea to change it out after the first 1000, change at 3000 or so for the first few intervals, and then if you feel like it you can start stretching it out to 5000 etc.
Also, im not sure exactly what goes on at a mass engine production facility, but when you put an engine together youreself, theres one very important step, lots and lots of assembly lube. Im not sure if they even use assembly lube, or whether they run it and flush it (i assume the test run the motors), but if for whatever reason they didnt change the oil used after first startup, you would definetly want too. Since assembly lube is typically a graphite paste used as the only barrier between you're engine and a few seconds of bone dry operation, it's pretty thick stuff, so after the first run you flush it out.
chochocho
May 13, 2004 07:46 PM
doodoobrown
Mar 31, 2004 07:15 PM
jimr
Nov 14, 2003 12:45 PM
supra_man
Sep 4, 2003 12:11 AM
snoserf
May 10, 2003 09:00 AM
