help with radiator
Old Jun 15, 2014 | 12:02 PM
subie07's Avatar
Car Info: 2007 wrx
help with radiator
Hey guys so I have an 07 wrx...it has been running just fine, no problems. All of a sudden when heading back to work, I noticed smoke coming out from under the hood. I parked the car and turned it off. When I looked at the front, there was coolant sprayed all over the front of the car, and coolant just draining from underneath the car. Any idea what this could be? Maybe a busted radiator, hose, or thermostat?
Old Jun 15, 2014 | 04:21 PM
Hipmvmt's Avatar
Car Info: 2004 Wrx wagoon
Could be all three of your guesses. If it was my car i'd top it off, start it up and see where its coming from. You didnt overheat did you?
Old Jun 15, 2014 | 04:23 PM
subie07's Avatar
Car Info: 2007 wrx
Well my temp gauge spiked up pretty high, but luckily I was able to park the car and shut it off pretty quickly.
Old Jun 15, 2014 | 06:20 PM
FL4T's Avatar
Car Info: 06 AW STi
I just had this problem a few weeks ago. Turns out that subaru used radiators with plastic end tanks top and bottom. the plastic just had enough and couldn't seal to the metal any longer and the coolant just exploded from the weak spot. I had to replace the whole thing, but this time I did it with a Koyo all aluminum radiator as I didn't want this problem to arise again. Good luck.
Old Jun 15, 2014 | 07:38 PM
Hipmvmt's Avatar
This, if it is your rad i would recommend replacing with an all aluminum aftermarket one. If it's a hose, silicone hoses are a hell of alot better to work with then oem rubber.
I had a radiator and the lower rad hose blow on me on two separate occasions, it overheated once. 500 miles later my head gasket went so watch for signs of that afterwards.
Old Jun 15, 2014 | 08:33 PM
subie07's Avatar
Car Info: 2007 wrx
I found the problem. Turns out it was exactly that. The plastic couldn't handle it anymore and It cracked. There's a long crack across it. It cracked right under the intake. The only way to see it is to take it off. I'll shop around for a new one. Thanks a lot to the both of you! I appreciate the help.
Old Jun 15, 2014 | 08:38 PM
subie07's Avatar
Car Info: 2007 wrx
Originally Posted by Hipmvmt
This, if it is your rad i would recommend replacing with an all aluminum aftermarket one. If it's a hose, silicone hoses are a hell of alot better to work with then oem rubber. I had a radiator and the lower rad hose blow on me on two separate occasions, it overheated once. 500 miles later my head gasket went so watch for signs of that afterwards.
What signs should I watch for?
Old Jun 19, 2014 | 09:19 PM
Hipmvmt's Avatar
My headgasket started with tiny exhaust bubbles in the coolant, and progressed into pushing coolant into the reservoir tank and overflowing it.
Other things that can happen when a headgasket goes would be oil in your coolant or coolant in your oil, exaust in oil or cooland ststems, or oil leaks around the head gasket.
Dont worry too much about it though, just check your fluids regularly, dont be afraid to ask here if you see something that strikes you as odd.
JelloChex
Feb 11, 2011 05:20 PM
Island Style
Hawaii Classifieds
May 12, 2010 05:41 PM
Subadubaru
Feb 10, 2010 10:35 PM
Drew's rex
Jan 4, 2009 12:20 PM
sneakywrx
Aug 14, 2007 01:43 AM
