Engine hygeine
Old Jan 19, 2003 | 03:34 PM
Kean's Avatar
Car Info: 03 WRX / 08 Forester
Originally posted by Blue-Adept
Try Tin Foil. It stay's in place better than Plastic Wrap. Tin foil will not burn or stick the plastic wrap does.
Blue Adept
This shouldn't be an issue since you should never rinse a hot engine.
Old Jan 20, 2003 | 08:48 AM
Kean's Avatar
Re: Hot engine
Originally posted by Collins
Kean,
It isn't a real issue,{hot engine}. All "degreaser"
instructions admonish user to let engine "cool", prior to
application. I believe prior respondants were recommending
effective methods of protecting "water sensitive" components
{ie. alternator}. Thanks for all responses, Colins
When Blue-Adept cautioned againt using plastic wrap for fear that it may burn, I could only assume he was talking about using the material on a hot engine. Just pointing out that you shouldn't spray water on a hot engine.
Old Jan 22, 2003 | 04:56 AM
lakepop's Avatar
Lightbulb
Wash a warm (not hot) engine using any degreaser you find suitable.
Do NOT use high pressure around electrical components!
Do use tin foil .....precludes any sticking/melting issues...better to be safe than sorry. Cover all electrical thingies..including throttle position sensor.
I do this twice a year...engine stays pretty nice.
Old Jan 22, 2003 | 08:56 AM
Kean's Avatar
Get real! I never would wash any thing but a warm engine. If you were to try to clean a cold one in Michigan in the winter you would have a enginecicle. ( Right now it is 6 degrees out side ) I always use tin foil because it stay's put. You can form it around a warm alternator, Ait inake. It does not blow off like plastic wrap.
A warm engine also makes any greasy grime clean up nicely.
Now I am talking warm 100 degrees not HOT.
And what is with the whole atitude thing lately on the forums. I was just explaining what I have been doing for the the last 18 years on my cars. People need to cut the negative feed back and work to help other Subaru People.
I'm assuming your not referring to me throwing off an attitude towards you.
Salty
Jan 28, 2004 07:45 PM
IllNastyImpreza
Sep 29, 2003 08:06 PM
seb
Jun 1, 2003 12:30 PM
rash
May 17, 2003 12:32 PM
