Can my Wrx pull a boat with 2325 pounds?
Old Feb 15, 2005 | 12:52 PM
davisvans's Avatar
does anyone know if i can or can not? i know its up to 2000 pounds but would that 325 pounds extra hurt?
http://www.bayliner.com/runabouts.as...4195&year=2005
thanks
Old Feb 15, 2005 | 01:18 PM
MVWRX's Avatar
Car Info: '05 Crystal Grey Metallic WRX Sport Wagon
...you have to add the weight of the trailer too...
Old Feb 15, 2005 | 01:22 PM
HellaDumb's Avatar
Car Info: 72 Vespa with curb feelers
thanks
I thought the WRX was only rated for 1500 lbs? Have you looked at the label on your hitch?
I've towed a small utility trailer but would never tow more than that. With approx 1,000 lbs, it feels like a full size truck is pushing you when you try to stop.
I think it's more of a brake/ safety issue, than it being a problem of getting it moving. Power isn't an issue, either, but I'd worry about ripping the car in half with that much weight.
I don't think the hitch is even rated above 1500lbs, but I could be wrong.
Old Feb 15, 2005 | 06:58 PM
shaunromano's Avatar
Car Info: 05 sti blue
yeah bro it would pull it but not safely.
Old Feb 15, 2005 | 08:34 PM
gotwrx's Avatar
Car Info: Silver WRX wagon
I'd say definately not recommended and probably illegal. If its a short distance (less than a mile) on the flat private street you'll probably be ok so long as the trailer is well balanced. But going any distance up grades on public streets in traffic like you might to get to a lake you are asking for trouble.
There are several issues to consider.
1. the WRX does not have a lot of low end torque so you'll be stressing the engine. Its gearing is not oriented for towing so it will be hard to manage
2. the unibody construction and suspension are not designed to safely tow more then the rated amount. If you overload it you might damage the frame
3. The towbar frames made for the WRX are class 1 which are only rated up to 2000 lbs. They have the smaller reciever (1.25 inch I think). If it's overloaded it may fail under any unexpected stress.
4. The maximum is a maximum and you probably shouldn't tow a load much over half that rating to be safe. The load weight includes the trailer. There's also the tongue weight to consider.
5. To tow over 1500lb you will need to add a trailer braking system. (by law in CA) You probably should consider one for any load over 1000lb. Not really relavent but good to know.
Bottom line - If you want to tow something that big you should get a more suitable vehicle.
Old Feb 16, 2005 | 12:23 AM
bpang1's Avatar
Car Info: '04 WRX Wagon
I think you should do it...then when the car pulls in half we can make an "Owned" picture
:banana:
Obviously, this is a bad idea.
Old Feb 16, 2005 | 06:57 AM
yzercyber's Avatar
Car Info: 03 WRX Sedan MBP/17X7.5 SSR Comps/225 Kumho MX
Don't even try it, please. Honestly, buy yourself a used full-sized pick-up to haul the tupperware so you don't ruin the little WRX. I have a boat and know that you need to consider the weight of the boat and trailer, driving on the freeway in crosswinds and hauling your boat and trailer safely in and out of slippery launch ramps. You want surplus power available...
Old Feb 16, 2005 | 11:42 AM
bpang1's Avatar
Would be funny to see the boat pull the car into the drink...well not really...maybe like 10 years after it would be funny.
Old Feb 16, 2005 | 11:58 AM
HellaDumb's Avatar
thanks
By the way, I'm planning on getting that same exact boat. Where are you getting it from?
I was going to pick up a used F150 or Chevy C10 to tow it.
Old Feb 16, 2005 | 12:23 PM
yzercyber's Avatar
yeah, and if you guys are headed out to the Delta don't forget to figure on an additional hundred lbs. for the brew. I'll bring the heineken.
Old Feb 16, 2005 | 12:36 PM
gotwrx's Avatar
don't be like this guy
http://dl.iskon.hr/webcafe/caravan.wmv
Old Feb 16, 2005 | 01:01 PM
MVWRX's Avatar
Hahaha, holy crap that's funny...
GDB-EJ20's Avatar
Car Info: Its a gross polluter : (
haha thats funny!
Old Feb 16, 2005 | 09:10 PM
davisvans's Avatar
yeah, thinking of getting a used 4runner or something. the fact is i dont want to fad in another 6-7 grand just for a boat
theres a place near us boat in oakland, my friend got a 21 and half bayliner there. i'm going there this weekend, pm me if you wanna join, we might get a better deal if we get two.
davis
