HELP! Major driveability problems after stereo install
Old Sep 1, 2007 | 10:19 PM
soobie2002's Avatar
Car Info: 2007 Subaru WRX STI
OK, so I took my '05 STI to circuit city last week to get a stereo, amps and subs installedand when I picked up the car my check engine light was on and the car drive like crap, I basically lost boost pressure. I took it to my subie tuner and we found multiple codes (speed sensor, o2 codes, running lean or rich). However, the map was still intact and the ECU did not go back to original programming or anything.
Here's my set-up: Cobb pro-tune, Cobb TBE, Upipe, FP20G turbo, larger injectors, spt intake
Took back to Circuit City and they spent 2 days looking over their wiring job and basically found nothing except that the cruise control plug was unplugged. Basically they are trying to say that because of the mods, something must be wrong mechanically and its nothing they could have done. However, the car had been running fine up until the point they installed the stereo.
The car drives a bit better, the turbo is spoling, but I still have very little boost. Basically over 4000rpm, boost pressure cuts out.
So, to all you stereo installers out there, have you ever heard of this or run into a problem like this?? If so, what could be the problem? Could they have tapped into a wrong wire that would cause these types of driveability issues?
(PS- 02 sensor good, no vacuum leaks)
Thanks in advance!
Old Feb 18, 2008 | 05:13 PM
BeE_JiZZeLs's Avatar
Car Info: bugeye WAR wagon
they probably unplugged ur battery... as u should know, ur ecu/acessport won't hold memory when there is no power.
Old Feb 18, 2008 | 06:06 PM
ipozestu's Avatar
Car Info: Broken Subarus
Accessport writes to the ECU. Maps are stored even if power is disabled.
Old Feb 18, 2008 | 06:21 PM
^^^ o ok i'm wrong my bad... i don't have an a/p but a friend of mine did and i remembered some sort of map had been erased when we switched out his battery iono. don't listen to me, i'm from the internet!
Old Feb 18, 2008 | 06:22 PM
VRT MBasile's Avatar
not to mention....the thread is from Sept. any responses should be posted in the thread that linked you here (its ok, I almost did the same thing)
Old Feb 18, 2008 | 09:25 PM
xhengmanx's Avatar
old thread but it may have been that they tapped into the ecu power or ground
Old Feb 19, 2008 | 09:30 PM
Steven@Coach's Avatar
Car Info: 2011 WRX Hatchie
If they even probed an ECU wire with a crappy meter it could screw it up. Plus most aftermarket decks aren't compatible with Subaru speed sense, see if that is hooked up.
Old Feb 19, 2008 | 10:47 PM
o9spitfire9o's Avatar
Car Info: impreza 2006
what did you get installed exactly?
i<3dirt
Oct 20, 2014 10:26 AM
Emsraumajunke
May 29, 2006 07:22 PM
Wingless Wonder
Oct 7, 2004 11:25 PM
jimr
Dec 29, 2003 11:39 PM
jasno999
Jun 14, 2003 08:15 PM
