CEL: P0122 Throttle Position Sensor/Switch A Circuit Low Input
Old Dec 24, 2013 | 09:36 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
So just recently, I have been getting this CEL P0122. I was wondering if anyone had ever encountered this issue and when they went about it. I did some research (https://www.i-club.com/forums/hawaii...-2-0-a-169554/) but i am just want to make sure that i am going at the right direction with it.
I am looking to order one of these. TPS (scoobymods.com)
Because the sensor is spring loaded, to turn it 90 degrees to reload the tension and reinstall.
Hopefully, this will clear the CEL and fix a rough idle. Any inputs before I put in the work? thanks!
Old Dec 24, 2013 | 10:09 AM
The Law's Avatar
Bad Mudder Trucker
whack!
Old Dec 24, 2013 | 12:04 PM
Vladi's Avatar
In Russia, Title Choose You.
Car Info: Everywhere
Pretty sure I have a spare hit me up.
Old Dec 24, 2013 | 04:27 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
Ill let you know. Thanks brotha. My buddy has one still on a throttle body so imma just unbolt my throttle body and put his one on with the tps on it.
Old Dec 31, 2013 | 08:43 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
just to keep this thread updated because im stuck with this insomia issue...and if anyone really cares lol..
I headed up getting a extra throttle body and TPS from my buddy Sum.
I cleaned it out with throttle body cleaner and elector cleaner to clean the sensors.
New gasket for the IACV because the old one expanded and is no longer able to reuse.
New gasket for the Throttle body becuase it ripped.
New gasket for the BOV because i had to unbolt the bov to remove TMIC.
I ended up cleaning out the MAP sensor and the IACV. the IACV was totally clogged and nasty. I used about 10 q tips and alcohol to clean it out and then install botht he MAP sensor and IAVC on the new and cleaned throttle body.
if anyone wants to know and have bogging or issues pertaining Idle. IACV is forsure something you want to check and potentially clean. Also have a handy gasket. they are 6 bucks at subaru. ( i also hear you can just fill the IACV with gasoline and let its sit so that it breaks down the gunk in there too.)
everything was fine to reinstall execpt for the friggen TMIC. that plast y pip was a PIA to put back in but i ened up getting everything reinstalled at 5 this morning.
I am going to next fire the beast up and let it idle for 10 mins so that the IACV gasket can expand. Then take it for a run and see if everythign clears up. Update this later today..
Old Dec 31, 2013 | 09:14 AM
I had P1088 for the TVG sensor
https://www.i-club.com/forums/show-s...4/#post2892128
Old Dec 31, 2013 | 09:23 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
haha im hoping this isn't the case yet.. anyway, but if it is so I'll follow your instructions. I remember reading some where, where you have to rotate the sensor 90 degrees? I took off the same sensor off the old throttle body and i tried to turn it 90 degree but the holes then wouldn't aglin.. i just put it back in and slightly turned it.. Im wondeirng if its the same case here as the TGV...
thanks thomas.
Old Dec 31, 2013 | 02:27 PM
Ya the one I did was spring loaded and you had to have it turned to have everything lined up. Then slowly crank it over to get the holes to line up to tighten it down.
Old Jan 1, 2014 | 08:40 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
Update. Turned the car to on position 3 times for the fuel pump and then turned it on. Rpm settled at 2k rpm since it was cold start. I just let it run for about 10 mins and eventually it went from 1500 and drop to about 8 to 700 rpm on idle. No leaks at the moment. So I'll give it a few runs later today. So far everything is smooth woot!
Old Jan 1, 2014 | 01:34 PM
Very nice
Old Jan 1, 2014 | 02:02 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
Very nice
Hah yepp.. Drove it around and everything is fine rpm drops to 1200 and slow works to 700 rpm. Kinda surprised because not everything works out accordingly. Usually its one thing and then another. Anyways good start for a new year
Old Jan 23, 2014 | 09:13 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
to update after 2-3 weeks from cleaning and reinstalling of the new sensor.. the PROBLEM is FIXED. No bogging or idleing issues anymore. I was concern about maybe a slight raise in temp , but it all worked out.. the car idles at drops form 1100 to 700 and stays at 700 rpm. Hopefully this helps anyone that maybe going through this process in the future.
Old Jan 23, 2014 | 09:23 AM
Good to hear its all taken care of!
kevin_ej20
Apr 11, 2007 06:34 PM
ASpec818
Dec 11, 2005 06:54 PM
Hatteroo
Oct 16, 2005 09:10 AM
Rad One
Mar 24, 2005 11:59 PM
glyphic
Nov 4, 2003 11:58 AM
