STIchris unrivaled built sti
hey whats up my name is chris i own a 2004 sti.....and im in the middle of a pretty awsome build i think.... my old block had 73,000 miles on it and still was running strong..before i took it apart i was running 100% meth with a 750cc meth nozzle, aps inlet, aps 65mm intake, with stock turbo at about 26 28 psi a lil much for that turbo but the car was great it was alot of fun and in the spring of 2010 i started my new build and this is what im doin
THANKS ANDY AND STEVEN FOR BUILDING IT YOU GUYS TRULY KNOW WHAT UR DOING HIGH 5 !!UNRIVALED PERFORMANCE FTW !!
Engine:
[color=#00BF00][LIST]
-Power-
ej257 block
Stock STI Crank
cosi Main and Rod Bearings
manly turbo tuff rodz
CP Pistons 9.0 compression
stock Head Gaskets
04 STI Heads with minor porting
bc 272 Cams
BC Valves, springs, and retainers
ARP Head Studs
Killer B oil pick up
08 Oil Pump
TGV Deletes
ID 1000cc Injectors
gates supper strong kevlar timing belt with gates water pump and random parts
Dw 300
top feed conversion
AMS Intercooler black
Tial Q BOV
PTE 6262
GT spec uel header with rotated up pipe
1 44mm ewg
custom down pipe
Tial 44mm EWG
Invidia n1 Catback
Perrin Lightweight Pulley
Mishimoto Radiator
Crawford aos
1 step colder spark plugs
p & l avcs line
P&L power steering line
reveres intake manifold with custom ic 3 inch from ic 2 tb just under 3 feet.... 2.5 from turbo to ic pipe just over 4 feet i got rid of just over 5 feet of pipe
aeromotive fpr
-Handling-
Perrin 25mm Front & Rear Swaybars & Endlinks
Perrin Rear Control Arms
Tein flex coilovers
top hats with camber adjustments
ARP front strut brace
-Drivetrain-
KARTBOY REAR DIFF BUSHINGS (race)
kartboy rear diff crossmember locking bolts
Tic tranny crossmember bushings(race0
Kartboy outrigger bushings (race)
Kartboy Short Shifter
kartboy front and rear shifter bushings (race)
Torq solution pitch stop
Torq solution engine mounts
Torq solution trans mount
ACT Heavy Duty 6 puck
Beatrush Propeller Shaft Mount aluminum bushings
Wilwood 4 piston front brakes
-exterior-
wingless??
its all about the go not the show
-interior
gauges egt,oil temp,oil psi, water temp, boost,afr,fuel psi stir gauges
ati clock pod and steering column pod
some pics
of the build
a pic my buddy did for me
Engine:
-Power-
ej257 block
Stock STI Crank
stock Head Gaskets
bc 272 Cams
ARP Head Studs
08 Oil Pump
TGV Deletes
ID 1000cc Injectors
Dw 300
top feed conversion
Tial Q BOV
PTE 6262
1 44mm ewg
custom down pipe
Tial 44mm EWG
Invidia n1 Catback
Mishimoto Radiator
Crawford aos
p & l avcs line
aeromotive fpr
-Handling-
Tein flex coilovers
-Drivetrain-
-exterior-
wingless??
-interior
some pics
of the builda pic my buddy did for me
speedykanaan
Jul 20, 2012 12:23 PM
NorcalCarbonWRX
Mar 18, 2010 01:11 AM
NorCalDC5
Jul 22, 2009 10:35 AM
bugeyehybrid
Cars For Sale
Nov 14, 2006 09:48 AM
