F/s engine parts
Old Mar 9, 2013 | 08:47 PM
garcia_er64's Avatar
Car Info: 2000 2.5rs
F/s engine parts
several engine parts that i no longer need
03 wrx heads 90xxx miles, engine had low compression due to rings
04 wrx heads around 60 xxx miles
only have one set of wrx valve covers
07 wrx heads 16xxx miles on them, new valve seals
05 ej257 shortblock with acl main/rod bearings, arp head studs, seal kit from the dealer, wrx oil pan, sti pistons with 500 miles or so with new rings from dealer. rebuilt shortblock about a year ago it has never been ran
03 ej20 crnaksshaft and rods 90xxx
03 ej20 case needs to be bored over
05 sti engine harness
03 wrx harness, missing crankshaft position sensor connector
legacy oil pan
wrx oil pump used
stock gc front sway bar and i believe is a stock wrx (20 mm) rear sway bar
02-07 wrx/sti non-bellmouth catless 3 inch down pipe
have more need to check
need to get rid of this stuff, flexible on prices PM or text
408-628-8695
thanks
Old Mar 11, 2013 | 09:37 PM
bump
Old Mar 11, 2013 | 10:01 PM
con10der_8's Avatar
Car Info: 2003 WRX PDM
Bump!! Thank u for the quick response
Old Mar 17, 2013 | 12:53 PM
PurplePlatty's Avatar
Car Info: 2000 Outback Sport
You've got PM!
Old May 20, 2013 | 09:50 PM
2x 2.0 WRX heads 200$ pair
ej257 short block 1500$ O.B.O
07wrx heads 500$
bunch of stuff i need to get rid of!! will not ship. everything is ObO, need to get rid f this stuff
weezy
Subaru OEM Parts For Sale
Apr 12, 2005 06:19 PM
IllNastyImpreza
Sep 29, 2003 08:06 PM
seb
Jun 1, 2003 12:30 PM
rash
May 17, 2003 12:32 PM
