Help! Help! Help!
Old Dec 4, 2007 | 08:38 PM
neo2983's Avatar
Car Info: 2002 wrx
Help! Help! Help!
ANYBODY KNOW THE NAME OF THIS PART? IT BROKE OFF WHILE SHIFTING
<a href="http://photobucket.com" target="_blank"><img src="http://i95.photobucket.com/albums/l137/neo2983/fastwrx_1974_9320455.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Old Dec 4, 2007 | 08:39 PM
neo2983's Avatar
Car Info: 2002 wrx
Old Dec 5, 2007 | 10:21 AM
ipozestu's Avatar
Car Info: Broken Subarus
Broke Off while shifting? WTF. Are you talking about the bushing?
Old Dec 5, 2007 | 01:31 PM
OneManArmy's Avatar
General Pimpin'
damn jeff.....even you can't break that one.
no clue what that's called.
what circled is the bushings. If you're talking about that entire part I think you're gonna have to replace the entire shift set up.
Old Dec 5, 2007 | 03:00 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Did the linkage break or did the bolt that attaches it to the trans break? Also do you have aftermarket bushings i.e. Kartboy? What sometimes happens is that when the bushings are installed that bolt gets overtorqued (it isn't supposed to be torqued down that much) and can break either right away or later on.
Old Dec 5, 2007 | 04:25 PM
to add a little bit they are can be installed backwards too
it happened to me
you cant get the car in gear
Old Dec 5, 2007 | 05:58 PM
Mulder's Avatar
it happened to me
What gets installed backward is the retaining washer, which has a tab on it for the external return spring that is no longer used but was there on older GC's. With the tab in the wrong place the shifter won't go into all the gears.
Old Dec 5, 2007 | 07:11 PM
OneManArmy's Avatar
General Pimpin'
good info.
