Tips on installing a Air/Fuel ratio gauge on a 92 legacy
Old Jan 17, 2005 | 05:01 AM
ryno50485's Avatar
Car Info: Subaru legacy/soon to be WRX
Question Trouble installing an Air/Fuel ratio gauge on a 92 legacy
Hey guys, i just wired power wire into the ignition so the gauge turns on when my ignition is on, as well as a ground wire.
Then i wired the third wire into my O2 sensor. There are 3 wires running into the sensor, i wired it into the black wire. I was told to tap into the signal sensor wire BETWEEN the PLUG and my ECU. I did that and it still doesn't register on the gauge. Did i use the wrong wire?
Old Jan 17, 2005 | 07:17 AM
Magish's Avatar
What model legacy is it? I take that it is probably a turbo?
Old Jan 17, 2005 | 07:33 AM
ryno50485's Avatar
Question reply
Its a non-turbo 92 legacy wagon. Can i install this gauge without a turbo and make it work properly?
Old Jan 17, 2005 | 10:41 AM
flvimpreza's Avatar
you can install a AFR even on non turbo cars. I have a 2.2l impreza and installed a autometer AFR. I got the schematics from ravensblade impreza. Some say install it before cat to get a accurate reading. Since we have boxer engines, installing it before cat will be on just 2 cyl on the right side of the engine. I could either weld a new O2 plug and buy another o2 sensor. Too much work decided to install it after cat, replaced the cat with a hi flow cat and works pretty good.
Old Jan 17, 2005 | 01:37 PM
ryno50485's Avatar
I'll probably try to wire it into my existing O2 sensor
knightsnke
Misc Items For Sale
Apr 25, 2005 10:32 PM
Ender2664
Mar 15, 2004 04:20 PM
OverBooster
Aug 13, 2003 10:42 PM
Kevin02REX
May 8, 2003 07:51 AM
GM991
Mar 6, 2003 08:32 AM
