Rat chewed on a wire, now car won't start ! Help !
Old Jul 12, 2003 | 01:07 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
That sucks...in a funny kinda way.
It looks like Templeton got the crank sensor wire, which I believe is shielded. And, unless SOA has changed recently, you can't buy pieces of wiring harnesses.
For best reasults, I bet you're gonna have to replace the entire engine harness, which sounds scarier than it really is.
Paul
Old Jul 14, 2003 | 12:08 AM
go go go's Avatar
Car Info: GF8 ver6
man, this sucks...
Looks like you need to replace the engine wiring harness.
It is one piece so need to buy the whole thing, wiring harness is really expensive.
To replace the harness, you need to take off the intake manifold and that's a lot of work too..
If you can reach, maybe you should try to fix it by soldering the wire. You got nothing to lose, give it a try. Make sure to disconnect the battery when you do it. Good luck.
I hope there is no more damage in the area where you can't see.
You can take off the alternator and powersteering pump fairly easy. Less than 15 minuites. Just unbolt the bolt you see. That'll give you more room to reach to the wires
peterislazy
Aug 15, 2008 09:32 PM
03_Impreza_Al
Nov 16, 2006 10:42 PM
Scoober02
Nov 24, 2004 03:25 PM
Wagon Joe
Dec 10, 2003 01:18 PM
EddyRS
Oct 18, 2003 01:29 PM
