Replace shifter panel light?
I have a 97 Legacy GT wagon with an automatic tranny. The light bulb which illuminates the gear setting (R, N, D, 1, 2, 3) has burned out. Any ideas on how to replace this, before I just go after it with a screwdriver?
Might be a good idea to look on Scoobymods. There's probably something on there related to replacing the bulbs with a different color, or whiteface gauge install, that'll go over the gauge cluster removal procedure.
Pull the ebrake on and put the shifter down into 1 or 2. open the center console, remove the two screws holding on the trim around the ebrake. The trim around the shifter will pop up. spin it 90 degrees so you can lift it over the shifter. Remove the 4 screws and you'll be able to get at the bulb in there.
I'm not sure what kind of bulb it is, but its pretty cheap at any parts store
nation
Feb 1, 2013 05:44 PM
chinaonnitrous1
Jan 26, 2010 11:14 PM
yaggi
Jul 9, 2004 08:06 AM
