heated seat switch...
Car Info: 2000 Legacy GT
I was wondering if anyone knew how to change the light bulb in the seat heat switch in a 2000 Legacy GT? Any help or links would be most appreciated.
Thanks!
Thanks!
probably the same as any other switch in the car...I think theres a faq for some lighting stuff over at scoobymods.
...but basically you pop out the entire switch and theres little screw like things on the side that you undo for access to the bulb. You should be able to figure it out once you've got the switch out.
good luck.
fibuz
good luck.
fibuz
Which blub? There are two of them in the switch. I have had the same problem, the bulbs can apparently be bought at radio shack, although I have been to a lot of radio shacks around where I live and none of them have had this part. I went to the dealer, and they said you had to buy a whole new switch to fix the problem, which would cost me 40 bucks, subarupartsonline has them for 20 bucks if you can't find the bulb.... If you do find the buld let me know what part it is so that I could order it online or something.....
rodsncones
SoCal Classifieds
Mar 27, 2006 10:12 PM
